Devo 7 using 2 RX's for controls on a Hexacopter
19 Jul 2015 12:26 #35654 by scmeyn
Hi All
This is a question using a Devo 7 (apparently not supported) but I am hoping someone may help. Presently run a RX701 with all channels filled. I have purchased a second RX701 as I am building retractable landing gear for my Hexacopter. I was able to bind the second receiver to the TX and have set up the gear switch to the second RX and it works all OK for the retractable landing gear. I also have a 3 axis gimbal and would like to use the Mix switch to operate the Yaw through the second RX on the gimbal as the pot (Aux 2) works the pitch of the gimbal on RX 1. Do I use the Function settings to access the Mix switch of do I have to somehow work it through the model settings. Any sort of direction would be appreciated?
Cheers
Time to create page: 0.183 seconds
