Can't Bind RX1002 with DEVO F12E TX
- maianunes
14 Jan 2017 11:34 #57933
by maianunes
Can't Bind RX1002 with DEVO F12E TX was created by maianunes
Recently I bougth two RX1002 for my DIY drones.
One I bind it with no issues using the procedure:
- Put Bind Plug in BAT of the RX
- Power ON RX (Red Led light's slowly)
- Power OFF RX and remove the Bind Plug
- Power ON RX (Red Led light's fast)
- Power ON TX F12E with Fixed ID (OFF)
- Red Led on RX turns solid (bind complete)
The Second Receiver RX1002 does the following:
- Red Led on RX keeps flashing fast (no bind)
I've tried several combinations of this procedure but nothing Works.
Do you have some idias to help me? Thank you
14 Jan 2017 15:24 #57939
Replied by FDR on topic Can't Bind RX1002 with DEVO F12E TX
Once you cleared the fixed id from the rx, there is no more need to use the bind plug, it is actually only for unbinding.
Simply turn on the tx with cleared fixed id, and within 10 seconds turn on the rx.
After this auto bind, you can set a fixed id and then send it to the rx with the bind button.
Next time you can turn them on in any order without any time limit and they will still be bound.
- maianunes
14 Jan 2017 16:21 #57940
by maianunes
Replied by maianunes on topic Can't Bind RX1002 with DEVO F12E TX
Thank you for your advice but that's what I did with no sucess.
The Red Led does not go solid. It keep's flashing quickly. No bind.
It's very strange, the Rx seems to work fine until the binding part.
14 Jan 2017 19:43 #57945
If it flashes quickly it means there is a fixed id stored in it.
You need to clear it first with a bind plug, but without the tx.
Plug in the bind plug, connect the battery, wait for slow flashes, unplug the battery and the bind plug.
- maianunes
14 Jan 2017 21:02 #57948
by maianunes
I did all that like I said in the first post, but the problem remains:
- Put Bind Plug in BAT of the RX, Power ON RX (Red Led light's slowly) = cleared fixed id
- Power ON RX (Red Led light's quickly)
- Red Led continue to flash quickly, never bind
I don't have more ideas.
Can the receiver his faulty? it's brand new...
14 Jan 2017 21:11 #57949
How quickly does it flash?
If it has fixed id it is very quick, but during the auto bind it is medium, about twice in a second.
Have you let it flash slowly at least three times during the fixed id clearing?
What do you mean on "Fixed ID (OFF)"? Have you cleared the fixed id value, so it shows "None" in the box?
- maianunes
14 Jan 2017 21:26 #57953
by maianunes
1º - I'm not certain but I would say about twice per second
2º - Yes, I let it slowly flash for about 1/2 minute (just did it again to be sure, but the result is the same)
3º - In the F12E menus I did the following:
- Model Menu - Fixed ID - Status Off
Then I power OFF the transmitter and back ON to bind
- maianunes
15 Jan 2017 12:57 #57966
by maianunes
- maianunes
15 Jan 2017 12:59 #57967
by maianunes
Forgot to mention that my Firmware is:
Hardware Ver. 1.2
Software Ver. 1.5A
Hardware Ver. 1.2
Software Ver. 1.5A
15 Jan 2017 13:08 #57968
Replied by vlad_vy on topic Can't Bind RX1002 with DEVO F12E TX
For original firmware Fixed ID = OFF equal to NONE for Deviation firmware.
Try to power on Rx with battery plug reversed to BAT (without bind plug at all), sometimes it helps to clear Rx Fixed ID.
- maianunes
15 Jan 2017 14:02 #57975
by maianunes
Done, but the problem remains, although the RX red LED starts to flash slowly as if he had the bind Plug connected
15 Jan 2017 18:34 #57993
Sorry, I didn't know that you are using the stock firmware...
- maianunes
15 Jan 2017 19:02 #57994
by maianunes
I've tried to install several Firmwares from deVention (Nightly Builds) but it was stuck all the time after flashing with a message USB "something" I don't recall.
Any way I don't think the Binding problem of this receiver is not the transmitter because it works fine with all the other receivers
- maianunes
15 Jan 2017 19:57 #57996
by maianunes
- SirDomsen
15 Jan 2017 20:17 #57997
by SirDomsen
Replied by SirDomsen on topic Can't Bind RX1002 with DEVO F12E TX
Well it's Deviation, not deVention.
Anyway: Now you need to,put the file system on your tx. Should show up as an USB flash drive while connected. Then just copy the files on it (or is it devo.fs for F12e also?). should be contained in the deviation .zip file.
- maianunes
15 Jan 2017 20:56 #58000
by maianunes
You are right. I already reinstall the 1.5A firmware.
Can you send me a link to download the latest DEVENTION firmware to F12E ?
- Artus
23 Jan 2017 01:42 #58310
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Can't Bind RX1002 with DEVO F12E TX
If you copy the devo.fs file from your pc via USB to your f12e deviation starts your tx
I had the same problem after installing deviation but now I am able to work with
- maianunes
23 Jan 2017 07:57 #58312
by maianunes
Thank you for your tip, but unfortunately when I connect the F12E to the PC (USB) normal mode, or in DFU mode, it doesn't appear in the PC explorer devices, although it appears in MANAGE DEVICE / USB CONTROLLERS / STM Device in DFU Mode
How did you copy the devo.fs to the F12E ?
- Artus
23 Jan 2017 15:31 - 23 Jan 2017 15:33 #58322
by Artus
Ok try this:
Download usb-driver changer (this one which changes from Walkara-Dfuse mode to Deviaton-downloader mode.
Restart every time your PC after changing drivers.
And Install Deviaton with all "enabled".
The f12E in usb mode must be detected as a small usb-drive.
You cant damage - you always can go back to the Walkera-firmware
If the F12E - drive is not detected - there is something wrong with your PC.
I will try to guide your installation - i have done 2 weeks ago - and after 2 nights its running
Last edit: 23 Jan 2017 15:33 by Artus.
Time to create page: 0.686 seconds
Stock Firmware Help
- Can't Bind RX1002 with DEVO F12E TX
