Can't Bind RX1002 with DEVO F12E TX
- maianunes
23 Jan 2017 15:53 #58324
by maianunes
Replied by maianunes on topic Can't Bind RX1002 with DEVO F12E TX
I downloaded the drivers in the link below, and install the "DFU USBDrv Installer-1.1" but still the F12E it's not recognize by Windows explorer on the PC.
www.deviationtx.com/downloads-new/category/161-dfu-usb-tool
What I'm doing wrong?
- Artus
23 Jan 2017 17:48 #58326
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Can't Bind RX1002 with DEVO F12E TX
You can delete every USB driver you find
After you have connected your F12E to your PC in USB-Mode - have a look at your device manager - what do you see there ?
- maianunes
23 Jan 2017 18:17 #58327
by maianunes
Finally I manage to install Deviation Firmware into F12E (What desapointment) I did a GUI to do it
GUI to install Deviation Firmware on F12E
First of all let say that this procedure will RESET EVERYTHING (settings, models, etc.) from the TX memory.
With the F12E unpluged from the PC:
1º - Run "DFU USBDrv Installer-1.1" and select "Remove all DFU drivers (and don't install any new ones)"
2º - close "DFU USBDrv Installer-1.1"
3º - Run again "DFU USBDrv Installer-1.1" and select "Install Deviation USB driver (for Deviation-Uploader)"
4º - close "DFU USBDrv Installer-1.1"
5º - Run "DeviationUpload-0.8.0.jar" and start your TX in DFU mode (press and mantain key "EXT" and power ON the TX)
6º - Should appear on TX display "Program Update......"
7º - Connect the F12E to the PC with the mini USB plug
8º - In "DeviationUpload-0.8.0.jar" go to "Install/Upgrade" tab Menu and in "Firmware" open the .zip file downloaded from
ex. debug-devof12e-v5.0.0-cd42b13.zip
9º - Select "Install/Upgrade" button
10º- After finishing the instalation of the Firmware go to "DFU" tab menu
11º- In DFU tab menu select "File" .dfu extracted from the downloaded .zip
ex. deviation-devof12e-v5.0.0-cd42b13.dfu
12º- Select "Send"
13º- Finally your F12E should have the Deviation Firmware uploaded
14º- Power OFF the TX and unplug it from the PC
15º- Power ON TX and enjoy.
12º- Select "Send"
Time to create page: 0.090 seconds
Stock Firmware Help
- Can't Bind RX1002 with DEVO F12E TX
