Devo 7E firmware update only boots to Prog update
- duane
04 Nov 2017 18:27 #65513
by duane
Devo 7E firmware update only boots to Prog update was created by duane
04 Nov 2017 21:37 #65517
Replied by mwm on topic Devo 7E firmware update only boots to Prog update
Did you update the protocols as well? If not, you need to.
- duane
04 Nov 2017 23:56 #65522
by duane
Replied by duane on topic Devo 7E firmware update only boots to Prog update
Protocols?
Sorry to sound lost but I am. A buddy brought his controller over to do the update and there seems to be so little documentation on the process I just got the first part done and now the controller only starts up with the Program Update screen like pressing the EXT and powering on. Does that on startup no matter what now.
Any documentation on updating the protocols?
05 Nov 2017 06:19 #65530
Replied by vlad_vy on topic Devo 7E firmware update only boots to Prog update
It looks like you have pressed "Upload" button and damage firmware file, then press "Upgrade" and flash damaged firmware file.
Download fresh firmware archive and try again. Then use USB mode and renew "protocol" folder (all filesystem if needed).
- duane
05 Nov 2017 07:21 - 05 Nov 2017 07:39 #65531
by duane
I have tried but as you can see from the screen shot I load the firmware file but the "Upgrade" button stays grayed out. All buttons but the Quit button are grayed out. It acts like the right version is loaded if you look at the "Available DFU Devices" Vendor ID, Product ID and Version they match the same on the File Information, but from that point on when you turn the 7E on it just goes to the same Program mode no matter what buttons you press during startup.
Last edit: 05 Nov 2017 07:39 by duane.
05 Nov 2017 07:36 #65532
Upgrading an existing instal is essentially identical to doing a fresh install. The only difference is you don't have to format the disk in the Tx, as it's already been done, and you want to avoid overwriting your existing config files.
That process has been very thoroughly documented in the second part of the manual: www.deviationtx.com/user-manual/user-manual-7e-10 . Reading the manual before hacking the device is highly recommended.
05 Nov 2017 07:49 #65533
I don't see Tx identifier at bottom, so Tx is not identified by Dfuse. Something wrong with USB driver.
- duane
05 Nov 2017 12:16 - 05 Nov 2017 12:18 #65549
by duane
OK I used the Java installer and now I get the USB screen when I start while pressing the ENT button and I get a drive F on my PC. I thought the documentation said if I used the jar/Deviation install I wouldn't need to do anything else. If I start the 7E without pressing a button I just get a blank screen. I know on the other documentation it said something about formating the drive (F) and then coping files to it but those were the directions that messed things up the first time. I don't want to make any mistakes but I'm at a loss where to go from here. Can I get some help?
Last edit: 05 Nov 2017 12:18 by duane.
- aMax
05 Nov 2017 12:38 - 05 Nov 2017 12:44 #65550
by aMax
Replied by aMax on topic Devo 7E firmware update only boots to Prog update
drive.google.com/drive/folders/0B6SupsT8-3_BYXNQM1dOUlRYcGM
....a link from the Deviation download section.
Dfuse USB upgrade tool,...get version 2.31.
Edit:
Here you will find what you need to know.
www.deviationtx.com/forum/3-feedback-que...-on-windows-xp#64897
Edit:
Last edit: 05 Nov 2017 12:44 by aMax.
- duane
05 Nov 2017 12:44 - 05 Nov 2017 12:46 #65551
by duane
Last edit: 05 Nov 2017 12:46 by duane.
- aMax
05 Nov 2017 12:52 #65552
by aMax
If you can´t download a specific file, try "download all"....which gives you a zip file of 17Mb.
Windows10 user..?
Windows10 user..?
05 Nov 2017 12:58 #65553
- duane
05 Nov 2017 13:29 #65554
by duane
- duane
05 Nov 2017 13:40 #65555
by duane
- duane
05 Nov 2017 14:44 - 05 Nov 2017 14:45 #65556
by duane
Windows 7
Last edit: 05 Nov 2017 14:45 by duane.
- duane
05 Nov 2017 15:30 #65557
by duane
Got it!
Thanks for all your help!
Time to create page: 0.324 seconds
Stock Firmware Help
- Devo 7E firmware update only boots to Prog update
