Upside down and backwards display
08 Jan 2020 00:12 #75673 by Eric B
Upside down and backwards display was created by Eric B
I have an older T8SG black and silver. Was working fine and then got stuck in usb. I was able to get it back by using the dfu tool and re flashing firmware. When I turned it on the screen is upside down and backwards? What have I done wrong? Anybody have an idea to help? It is more than likely operator error.
08 Jan 2020 05:42 #75674 by vlad_vy
Replied by vlad_vy on topic Upside down and backwards display
What do you use? Nightly build?
Try v5.0.0 build:
www.deviationtx.com/forum/builds/6407-de...cols?start=500#75331
If you got stuck in USB screen, you need restore filesystem, not firmware.
08 Jan 2020 15:17 #75677 by Eric B
Replied by Eric B on topic Upside down and backwards display
Yes I tried the nightly build. Could the version of the DFU I used cause the problem? I will try the link you attached. If that doesn't change it I think that I will start over from from scratch, whats the worst that could happen...
Thanks for your input and I will let you know what happens.
08 Jan 2020 15:30 #75678 by vlad_vy
I suspect you use wrong firmware, probably "deviation-devo7e-256", you need to use "deviation-t8sg" firmware.
08 Jan 2020 16:16 #75679 by Eric B
I tried the latest from Nightly build v5.0.0 dated today, still same issue. You mentioned "If you got stuck in USB screen, you need restore filesystem, not firmware. Dumb question how do I restore filesystem?
08 Jan 2020 16:26 #75680 by Eric B
FYI When I used the latest v5.0.0 build and copied it over to the TX I got the message the file was to big, so I unchecked the debug-t8sg zip file and the deviaton-t8sg DFU file and it loaded.
28 Jan 2020 16:50 #75839 by Eric B
Finally got it working. I probably was using "deviation-devo7e-256" and needed to use "deviation-t8sg" firmware. as vlad suggested. It usually is operator error on my part ha ha. Thanks for your help vlad
Time to create page: 0.294 seconds
