jummperTX T8SG is only showing usb
06 May 2020 17:50 #76248 by joshuaseth12
jummperTX T8SG is only showing usb was created by joshuaseth12
i just got a jumpertx t8sg and tried to play a sim on my phone and now its only showing usb on it can anyone help all i have is an android phone and a chrombook
06 May 2020 18:02 #76249 by pcrane87
Replied by pcrane87 on topic jummperTX T8SG is only showing usb
can you get into the files if you plug it into the computer and is it the T8SG plus
06 May 2020 18:08 #76250 by joshuaseth12
Replied by joshuaseth12 on topic jummperTX T8SG is only showing usb
no it says it not formated
06 May 2020 18:12 #76251 by joshuaseth12
here is what i see
07 May 2020 00:10 #76257 by pcrane87
I got jumper back to normal i can send you the files that i have to bring your back to life.
07 May 2020 00:19 #76259 by joshuaseth12
Thank if you can please send those over
09 May 2020 05:34 #76280 by eBoosted
Replied by eBoosted on topic jummperTX T8SG is only showing usb
I'm having the same issue on my T8SG V2 plus, only bootlooping on USB logo.
If I turn it on on boot mode it is accesible through deviation uploader, I can upload the firmware but get a usb logo after restarting
If I turn it on I get the USB logo and windows forces me to format the drive
If I format de drive I'm able to see the drive on windows again, should I just unzip the firmware and copy/paste it via windows without using the deviation uploader?
09 May 2020 18:46 #76286 by pcrane87
yes let me know if you need the files and i will send them to you
12 Jul 2020 20:37 #76583 by stevempotter
Replied by stevempotter on topic jumperTX T8SG is only showing usb
I have the same problem, just the USB logo on starting the T8SG Plus v2 carbon LCD.
The Transmitter name does not update in Deviation Uploader, and the manual says to consult the forums if that happens. (it remains Devo 7e).
Flashing t8sg_v2-5.0.0-1c43d1b.zip did not fix the problem.
I sent pcrane87 a PM for help. If anyone else has an idea what to do, please post here!
12 Jul 2020 21:53 #76584 by pcrane87
Do you want me to send you the files I have for my controller and I will send you the back up files I have for my controller.
13 Jul 2020 11:30 #76587 by stevempotter
Replied by stevempotter on topic jummperTX T8SG is only showing usb
No thanks, I got it sorted from Jumper customer service. I posted instructions in a new Topic along with their firmware for 3 versions.
Time to create page: 0.143 seconds
