Jumper T8SG builds
22 Sep 2017 05:07 - 29 Sep 2017 03:50 #64581 by vlad_vy
Jumper T8SG builds was created by vlad_vy
Since we havn't specific T8SG target or devo7e-256 build compatible with T8SG I will place here the builds for Jumper T8SG.
Changes:
* RUD and AIL reversed to comply with common direction for Deviation.
T8SG based on devo7e-256 Nightly Builds:
File deleted, see below...
Last edit: 29 Sep 2017 03:50 by vlad_vy.
25 Sep 2017 10:52 #64648 by SirDomsen
Replied by SirDomsen on topic Jumper T8SG builds
Cool!
But I assume that this TX opens Deviation for mainstream (no soldering etc. needed), wouldn't it be great to support it natively? What would happen if one flashes the U7e build? Only channels reversed?
25 Sep 2017 11:03 - 25 Sep 2017 11:07 #64649 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG builds
With devo7e-256 build you will get LCD screen upside down, RUD and AIL channels reversed. Also, I think if you will regulate LCD contrast, it will change strangely.
Last edit: 25 Sep 2017 11:07 by vlad_vy.
29 Sep 2017 03:52 - 04 Oct 2017 13:03 #64732 by vlad_vy
Changes:
* Fix quick pages for 128x64 GUI, from vladislavy
Last edit: 04 Oct 2017 13:03 by vlad_vy.
04 Oct 2017 13:05 - 09 Oct 2017 09:12 #64803 by vlad_vy
Changes:
* Rotary knobs (AUX4 and AUX5) direction reversed to comply with common direction for Deviation.
Last edit: 09 Oct 2017 09:12 by vlad_vy.
05 Oct 2017 06:49 - 14 Oct 2017 07:23 #64840 by vlad_vy
Changes:
* All four switches SWA, SWB, SWC and SWD reversed to comply with common direction for Deviation. You need exchange SW0 and SW2 values for used switches.
Last edit: 14 Oct 2017 07:23 by vlad_vy.
06 Oct 2017 19:57 #64882 by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG builds
Should be great to offer a default config file with all the four 3-way pre-configured :). Why not one dedicaced for D/R with three differents rate values....
07 Oct 2017 03:41 #64884 by mwm
Replied by mwm on topic Jumper T8SG builds
What you want is a template, not a model. A template will adopt to the protocol, where a model setup will depend on the protocol for which channels the D/R switch effects. Or are you thinking of changing the default model so that channel virt1 is a 3-way switch based on one of them?
08 Oct 2017 07:21 #64909 by SeByDocKy
mwm wrote: What you want is a template, not a model. A template will adopt to the protocol, where a model setup will depend on the protocol for which channels the D/R switch effects. Or are you thinking of changing the default model so that channel virt1 is a 3-way switch based on one of them?
What I was thinking is more a default config file where the 3-way switches are well configured for Betaflight for example .... So we just need to change the default protocol .... to our specific machine
08 Oct 2017 13:08 #64915 by Deal57
Replied by Deal57 on topic Jumper T8SG builds
I put together this template for a 6-channel multirotors based on CF/BF. I've tested with my Devo 12e, and 6s, but I don't have a T8SG to test. install in the templates folder then in Model setup scroll to choose the 6Ch Multi template. Let me know if this works for you.
The template assigns channels 1-4 to simple curves, channel 5 to arm (GEAR1) and channel 6 for modes (MIX). It also adds virtual channels for sticky throttle hold (virt1), Throttle % display (virt3) and Timer reset (virt 5). It automatically maps to the correct protocol and device layout. TEST WITH PROPS REMOVED. I haven't fully documented it yet...
09 Oct 2017 07:31 #64932 by SeByDocKy
Another small improvement can be maybe done. The Jumper is compatible with "60" config files .... so maybe by inserting 30 new config files from model31.ini to model60.ini .... should be a little nice add.
11 Oct 2017 16:13 - 13 Nov 2017 10:47 #64964 by vlad_vy
Changes:
* Fix switch mapping for foreign model files.
Now you can use model files from other devo transmitters with correct initial switch mapping with exception that all "DR" switches mapped to "SWD".
Switch mapping scheme:
("DR0", SWD0)
("DR1", SWD1)
("RUD DR0", SWD0)
("RUD DR1", SWD1)
("ELE DR0", SWD0)
("ELE DR1", SWD1)
("AIL DR0", SWD0)
("AIL DR1", SWD1)
("HOLD0", SWD0)
("HOLD1", SWD1)
("FMODE0", SWA0)
("FMODE1", SWA1)
("FMODE2", SWA2)
("MIX0", SWC0)
("MIX1", SWC1)
("MIX2", SWC2)
("GEAR0", SWB0)
("GEAR1", SWB1)
Last edit: 13 Nov 2017 10:47 by vlad_vy.
12 Oct 2017 15:15 #64993 by zarni
Replied by zarni on topic Jumper T8SG builds
Thanks for doing this.
Being my first Deviation transmitter, this update and your templates have made getting elevons to work much easier.
vlad_vy wrote:
Changes:
("DR0", SWD0)
("DR1", SWD1)
("RUD DR0", SWD0)
("RUD DR1", SWD1)
("ELE DR0", SWD0)
("ELE DR1", SWD1)
("AIL DR0", SWD0)
("AIL DR1", SWD1)
("FMODE0", SWA0)
("FMODE1", SWA1)
("FMODE2", SWA2)
("MIX0", SWC0)
("MIX1", SWC1)
("MIX2", SWC2)
("GEAR0", SWB0)
("GEAR1", SWB1)
Attachment not found
12 Oct 2017 17:16 #65000 by vlad_vy
It seems that it is the final version. I have no idea what else can be improved. The next builds will correspond to new Nightly Builds.
22 Oct 2017 06:11 - 23 Oct 2017 04:56 #65184 by vlad_vy
Changes:
* Fix AFHDS 2A channel scaling & tx power not in sync, from goebish
Last edit: 23 Oct 2017 04:56 by vlad_vy.
22 Oct 2017 18:55 #65208 by SeByDocKy
23 Oct 2017 04:56 - 25 Oct 2017 06:46 #65213 by vlad_vy
Summary of changes from stock T8SG:
Current changes:
* First shot at support for Bayang X16 with altitude hold, from TheRealMoeder
* Add IRDRONE format to Bayang protocol, from goebish
Last edit: 25 Oct 2017 06:46 by vlad_vy.
25 Oct 2017 02:16 #65237 by gvhlaw
Replied by gvhlaw on topic Jumper T8SG builds
SeByDocKy wrote: Another small improvement can be maybe done. The Jumper is compatible with "60" config files .... so maybe by inserting 30 new config files from model31.ini to model60.ini .... should be a little nice add.
SeBy - have you figured out how to get the RSSI feed on Channel 16 of an XM+ receiver to appear in Betaflight using the T8SG? Anyone else?
25 Oct 2017 04:43 #65244 by SeByDocKy
Did you turn on the "lastchRSSI" option ? If the RSSI is still not here.... it means you will need to flash the good XM+ Firmware .... via a Taranis radio for example.
25 Oct 2017 06:03 #65249 by gvhlaw
SeByDocKy wrote: Did you turn on the "lastchRSSI" option ? If the RSSI is still not here.... it means you will need to flash the good XM+ Firmware .... via a Taranis radio for example.
SeBy - I did set "LASTCHAN" on the Jumper - and so I need to find a Taranis I can borrow to flash the correct firmware. By the way, I seriously enjoy your reviews!
Time to create page: 0.133 seconds
