Jumper T8SG builds
13 Nov 2017 19:18 #65802 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG builds
From now Jumper T8SG builds can be found at Nightly Builds.
www.deviationtx.com/downloads-new/category/13-nightly-builds
13 Nov 2017 19:35 #65803 by gvhlaw
Replied by gvhlaw on topic Jumper T8SG builds
Vlad - will the T8SG builds be in their own sub-category? I don't see one now.
13 Nov 2017 21:10 #65805 by Moeder
Replied by Moeder on topic Jumper T8SG builds
You have to wait until tomorrow for the next builds to show up.
15 Nov 2017 05:42 #65841 by vlad_vy
It seems that T8SG is quite popular, twice as many downloads as for devo7e.
23 Nov 2017 14:31 #66100 by Neuer_User
Replied by Neuer_User on topic Jumper T8SG builds
Hi
Sorry for the probably stupid question. I just got my Jumper and wanted to update the firmware. I had done that several times on my Devo7e, so the general process is known to me. I downloaded this file: www.deviationtx.com/downloads-new/catego...g-v5-0-0-7eca2d7-zip
Now, it does not allow me to flash because of this error:
$ java -jar DeviationUpload-0.5-jar-with-dependencies.jar -send -dfu T8SG/deviation-t8sg-v5.0.0-7eca2d7.dfu
Found: DFU [00483:df11] cfg=1, intf=0, alt=0, name='@Internal Flash  '
Found: DFU [00483:df11] cfg=1, intf=0, alt=1, name='@SPI Flash: Config'
Found: DFU [00483:df11] cfg=1, intf=0, alt=2, name='@SPI Flash: Library'
Determining device status: statue=dfuERROR status=10
dfuERROR, clearing status
Determining device status: statue=dfuIDLE status=0
dfuIDLE, continuing
dfuIDLE, continuing
  Setting address pointer to 0x8000400
   Poll timeout 104 ms
bytes_per_hash=1024
Starting upload
Error: Dfu Tx type 'Unknown' does not match transmitter type 'Devo 7e'
Anyone knows what the problem is? To me it seems the firmware is expecting the Devo 7e instead of the T8SG?
23 Nov 2017 14:54 - 23 Nov 2017 15:10 #66101 by vlad_vy
I don't use DeviationUpload so I can't help. Try to use Dfuse, it works without problems.
P.S. Probably you need to use latest DeviationUpload-0.8
www.deviationtx.com/downloads-new/catego...ation-uploader-0-8-0
Last edit: 23 Nov 2017 15:10 by vlad_vy.
23 Nov 2017 16:25 #66103 by Neuer_User
vlad_vy wrote: I don't use DeviationUpload so I can't help. Try to use Dfuse, it works without problems.
Thanks for your help. I tried version 0.8, but it gives the same message. So, I searched for a Windoze box to install and run the Dfuse util and drivers. It worked :)
Unfortunately, my Jumper still doesn't bind my E010. No problem with the E011 that I also have, but no chance with the E010. Strange, my Devo 7e has no issues here... :(
23 Nov 2017 16:35 #66105 by vlad_vy
It's a matter of luck. You can try lower output power setting, sometimes it helps.
23 Nov 2017 16:50 #66106 by Neuer_User
vlad_vy wrote: It's a matter of luck. You can try lower output power setting, sometimes it helps.
Thanks. Yeah, I found this post:
www.deviationtx.com/forum/protocol-devel...ures?start=280#65222
I went down to 100uW. No chance. Seems I got bad luck :( Well, I'll try to forget the e010 and focus on other quads instead.
And, btw., thanks for all your hard work !!
30 Nov 2017 13:12 #66283 by wso55
Replied by wso55 on topic Jumper T8SG builds
try YD717 or CX10 with 100mwh or less
01 Dec 2017 15:49 - 01 Dec 2017 15:51 #66298 by campbell
Replied by campbell on topic Jumper T8SG builds
Deviation Uploader - 0.8.0
Transmitter shows Devo 7e
console shows
Tab: 1
How can I update my t8sg ??
Cannot bind to H36 (E010) MJXq
Deviation FW version: t8sq-v5.x.x-2017-10-11
Thanks In Advance
ken
Last edit: 01 Dec 2017 15:51 by campbell.
01 Dec 2017 16:05 #66299 by vlad_vy
Deviation Uploader - 0.8.0 can't update T8SG, you need use Walkera DfuSe Upgrade Tool.
01 Dec 2017 16:06 #66300 by FDR
Replied by FDR on topic Jumper T8SG builds
ATM you can use only the Walkera DfuSe Upgrade Tool to update the T8SG.
01 Dec 2017 23:06 - 03 Dec 2017 19:32 #66307 by campbell
How on Fedora??
vbox NOT exciting
Last edit: 03 Dec 2017 19:32 by campbell.
02 Dec 2017 00:42 #66309 by campbell
t8sq-5.0.0-e50fce3 firmware
h36 no bind with YD717 CX10 or MJXq
Suggestions??
Thanks In Advance
03 Dec 2017 19:39 - 03 Dec 2017 19:40 #66325 by campbell
Anyone know anything about FUQI FQ777
or maybe a Propel atom x01 ??
I would really like to use t8sg to learn to fly quads.. NO Direct3D so I'm trying on toys
Thanks In Advance
ken
Last edit: 03 Dec 2017 19:40 by campbell.
04 Dec 2017 00:05 #66328 by dc59
Replied by dc59 on topic Jumper T8SG builds
campbell wrote: t8sq-5.0.0-e50fce3 firmware
Suggestions??
Thanks In Advance
H36 is MJXq protocol and you should select sub-protocol "E010" under MJXq, if it still not bind , read this post
www.deviationtx.com/forum/protocol-devel...otocol-bind-problems
04 Dec 2017 00:17 #66329 by campbell
I have 2 blue ones neither binds. Changed to all the power settings no bind
what do they mean by antenna change? Removed t8sg antenna no at any power setting.
New t8sg with USB accessible. Latest nightly build
Thanks In Advance
ken
21 Dec 2017 12:26 #66553 by Bluedragon76
Replied by Bluedragon76 on topic Jumper T8SG builds
I flashed the 2017-12-18 deviation-t8sg-v5.0.0-4810939 and the timers do not function. Is there a fix or should I flash an earlier version?
21 Dec 2017 12:53 #66554 by FDR
What do you mean? What the timers don't do?
Are you sure you started them manually or with a switch?
Time to create page: 0.069 seconds
