Jumper T8SG builds
05 Nov 2017 23:25 - 05 Nov 2017 23:53 #65561 by SirDomsen
Replied by SirDomsen on topic Jumper T8SG builds
Hey!
Thanks for these builds. Just a question: I recently updated stock firmware to the latest build. Both Trim LH and LV are not working. I can use them neither as trim switches nor as virtual switches. The just seem to not work. I didn't test them with stock firmware, so I'm not sure whether it's a soft- or hardware issue. Wiring seems correct to me though...
Greetz
Domsen
Last edit: 05 Nov 2017 23:53 by SirDomsen.
06 Nov 2017 05:29 - 06 Nov 2017 05:56 #65565 by vlad_vy
Replied by vlad_vy on topic Jumper T8SG builds
In my case all trims work. Both for the Nightly Builds and for v5.0.0.
If both trim LH and LV are not working, it's problem with trims connection to B.7 (MCU pin 59). Probably it is the central soldering pad for both trims, they have to be interconnected on the main board. Also, B.7 is connected to central pin of SWA switch.
Last edit: 06 Nov 2017 05:56 by vlad_vy.
06 Nov 2017 06:49 - 06 Nov 2017 20:42 #65569 by SirDomsen
Thanks! Strangely SWA works as intended. Have to look into it further tonite...
Edit: Yeah, found and solved it. Somehow the center pin of the trims have no connection to B7. I didn't disassemble the mainboard so I didn't see where the trace is broken. Soldered a wire from,SWA's middle pin (which has continuity) to the trims. Thanks for the hint!
Last edit: 06 Nov 2017 20:42 by SirDomsen.
06 Nov 2017 23:58 #65593 by dc59
Replied by dc59 on topic Jumper T8SG builds
Hi vlad_vy,
I upgrade to Nov. 5 build, but I found all my models CH5 became "5-SW B" not "Ch5"
07 Nov 2017 04:22 - 07 Nov 2017 05:37 #65595 by vlad_vy
I don't understand why it can happen, but I will look into it.
Last edit: 07 Nov 2017 05:37 by vlad_vy.
07 Nov 2017 05:04 #65596 by glockgen4
Replied by glockgen4 on topic Jumper T8SG builds
where can i download this firmware sir T8SG based on devo7e-256 Nightly Builds?
it was deleted
07 Nov 2017 05:36 - 07 Nov 2017 06:03 #65597 by vlad_vy
I found it. The channel 5 name is GEAR, at devo7e GEAR is remapped by HOLD, at T8SG GEAR is remapped by SWB. It's channel name only and doesn't change anything.
It changed from 5-HOLD to 5-SWB starting from 2017-10-17 with changed the switch mapping.
It can't be removed since GEAR is used at Standard GUI presets.
I will look if I can change it.
Last edit: 07 Nov 2017 06:03 by vlad_vy.
07 Nov 2017 05:53 #65598 by dc59
vlad_vy wrote: I found it. The channel 5 name is GEAR, at devo7e GEAR is replaced by HOLD, at T8SG HOLD is replaced by SWB. It's channel name only and doesn't change anything.
Thank you very much.
07 Nov 2017 07:15 - 08 Nov 2017 05:21 #65600 by vlad_vy
Summary of changes from stock T8SG:
* RUD and AIL reversed to comply with common direction for Deviation.
* Rotary knobs (AUX4 and AUX5) direction reversed to comply with common direction for Deviation.
* All four switches SWA, SWB, SWC and SWD reversed to comply with common direction for Deviation.
* Fix switch mapping for foreign model files.
Current changes:
* Fix T8SG mixer page channel 5 name, from vladislavy
T8SG based on devo7e-256 Nightly Builds:
File deleted, see below...
Last edit: 08 Nov 2017 05:21 by vlad_vy.
08 Nov 2017 05:20 - 08 Nov 2017 06:47 #65630 by vlad_vy
Current changes:
* Fix T8SG channel 5 name for Standard GUI, from vladislavy
Last edit: 08 Nov 2017 06:47 by vlad_vy.
08 Nov 2017 06:49 - 11 Nov 2017 10:16 #65634 by vlad_vy
Current changes:
* Set T8SG default battery warning to 7.4V, default battery critical to 7.1V, from vladislavy
Last edit: 11 Nov 2017 10:16 by vlad_vy.
08 Nov 2017 07:12 #65636 by FDR
Replied by FDR on topic Jumper T8SG builds
I think it's time for a separate target, however before that, I would like to ask Jumper about their future plans with the T8SG variants...
10 Nov 2017 14:30 - 10 Nov 2017 14:31 #65703 by fneuf
Replied by fneuf on topic Jumper T8SG builds
Just to understand, the builds posted here, and the other posted in the "Deviation v5.0.0" dedicated thread are the "same spirit" ? Nightly I believe ?
In short, the 10th November revision posted there is the next revision of the 8th posted here ?
Last edit: 10 Nov 2017 14:31 by fneuf.
10 Nov 2017 14:42 - 10 Nov 2017 14:57 #65705 by vlad_vy
No, it is build based on stable release v5.0.0 (30 Apr 2016) with integrated fresh protocols and some fixes. Builds posted here are based on Nightly Builds.
Some users prefer to use stable release v5.0.0, so I decided add T8SG to v5.0.0. I also use the v5.0.0 and that's why I support v5.0.0 builds.
Last edit: 10 Nov 2017 14:57 by vlad_vy.
10 Nov 2017 15:23 - 10 Nov 2017 15:23 #65706 by fneuf
Ok, so in this thread I find something like "5.0.1ish" builds ? They integrate everything from "stable release v5.0.0 (30 Apr 2016) with integrated fresh protocols and some fixes" plus additions specifics to nightlies?
Last edit: 10 Nov 2017 15:23 by fneuf.
10 Nov 2017 15:32 #65707 by vlad_vy
Nightly Builds is quite far from v5.0.0, with the exception of protocols, they are synchronized.
10 Nov 2017 15:34 - 10 Nov 2017 15:35 #65708 by fneuf
Ok, and that is the log of differences?
Last edit: 10 Nov 2017 15:35 by fneuf.
11 Nov 2017 10:17 - 13 Nov 2017 05:43 #65744 by vlad_vy
Summary of changes from first batch stock T8SG (firmware "devo7e-256-v5.0.0-0ac6094"):
Current changes:
* Add fine frequency tuning option to A7105 protocols, from goebish
Last edit: 13 Nov 2017 05:43 by vlad_vy.
11 Nov 2017 10:23 #65746 by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG builds
Current changes:
Attachment not found
I was waiting for thos new A7105 options :) Thks :)
13 Nov 2017 05:44 - 16 Nov 2017 16:33 #65781 by vlad_vy
Summary of changes from second batch stock T8SG (firmware "t8sg-v5.x.x-2017-10-05"):
* Fix mixer page channel 5 name
* Fix channel 5 name for Standard GUI
Current changes:
* Fix S-FHSS protocol servo throw, from vladislavy
* Fix YD717 protocol binding when auto-ack is disabled, from hexfet
Last edit: 16 Nov 2017 16:33 by vlad_vy.
Time to create page: 0.121 seconds
