Input very aggressiv
- heli.li
13 Jan 2013 16:00 - 13 Jan 2013 16:32 #4977
by heli.li
Input very aggressiv was created by heli.li
Hi everybody.
I am new to deviation and I try to set up.
I have tried nerly everything, but I am not able to make my sticks less aggressive in the center.
It doesnt metter if i use linear or expo. In the output monitor (ail or rudd) it goes very fast from min to max with just touching the sticks.
From center the sticks move +/-25% brings output from +/-minmax and the rest of stick motion seams to be nothing.
How can I setup to use the entire stickmotion?
Of course I was able to set the output less aggressive, but also here in the monitor i can see that little movement of the stick will bring output from min to max.
Can anybody help me?
The issue affects only ail and rudd. (stickmovement right/left) gas and ele (up/down) works correct with same settings.
Maybe I have to reinstall firmware?
Last edit: 13 Jan 2013 16:32 by heli.li. Reason: only ail and rudd affected
- heli.li
13 Jan 2013 21:48 #4992
by heli.li
Replied by heli.li on topic Input very aggressiv
Sorry. I have found my problem. The calibration of the transmitter was not done correctly. Now it works fine.
Time to create page: 0.494 seconds
- Input very aggressiv
