Need EMU How To Use
24 Feb 2013 14:58 #6951 by gapi
Need EMU How To Use was created by gapi
Hi, Mr. Hard Head is Back, FYI I have DEVO 10.
I am attaching a screen shot of what I get when I try and run the EMU - "deviation-emu_devo8-848e6ada8ca7.exe".
I cannot use it because it does not respond to my mouse clicks. I believe I was told it would be a color mouse enabled one also.
In the background you will see the manual but it has nothing in the way of how to run the EMU.
I have my TX running 2.1.1 and in USB mode. I have tried it with and without.
I have Windows 7 x64 pro.
I guess I need a using the "EMU for Dummy's step by step.
24 Feb 2013 15:04 #6952 by FDR
Replied by FDR on topic Need EMU How To Use
You need to extract the appropriate filesystem too into the emulator's directory...
24 Feb 2013 15:14 #6953 by gapi
Replied by gapi on topic Need EMU How To Use
Thanks, Before I stumble onward.
I only see the EMU's in the nightlies download section. So, is this for nightlies only?
Say, The latest Devo 10 nightly with the Devo 10 EMU.
Or can I use other combos? And to confirm, I can save these models and run them?
Thanks,
24 Feb 2013 15:20 #6954 by Hexperience
Replied by Hexperience on topic Need EMU How To Use
Download the Devo 10 emu, extract it.
Download the Devo 10 filesystem, extract it to the same folder
You don't need to download the firmware for the emu to work, just the EMU and FS (filesystem) zip files.
24 Feb 2013 15:22 - 24 Feb 2013 15:23 #6955 by domcars0
Replied by domcars0 on topic Need EMU How To Use
Today you need also to download & extract (in the dir where is your emu_devo10.exe) this deviation-fs-devo10-7cfcdbf7b69c :
www.deviationtx.com/repository/Deviation...10-7cfcdbf7b69c.zip/
Last edit: 24 Feb 2013 15:23 by domcars0.
24 Feb 2013 15:30 #6956 by gapi
Thanks,
I have it going. The DOS screen is scrolling:
Transmit successful
Switching to receive mode
Switching to transmit mode
Changed Channel to
And so on non-stop? Is this the norm?
What mode is required if any for the TX to be in.
Thanks.
24 Feb 2013 15:50 #6958 by gapi
Well, Sigh!
You guys are great but I gotta sound off........
Is there supposed to be a manual on how to use a particular EMU and its key stroke commands some place?
I am not as dense as I seem here believe me.
I have written my own custom skin GUI for the MIO c520 GPS, I build and clock my own and friends and family computers. I am an industrial maintenance technician of 30 years. Have dealt with Allen Bradley PLC's and more.
Never in my life have I had to encounter such vague or such prerequisites such as coming from the Womb already knowing what to do.
Again you guys are great and I need you I just wanted to let you know I am head banging over here and without you I am in a spin.
If and when I get this, if you guys do not give up on me, I am going to write a step by step for other poor slobs like me who stumble in here.
Getting this stuff in pieces is killing me.
24 Feb 2013 15:51 - 24 Feb 2013 15:51 #6959 by domcars0
gapi wrote: Thanks,
Transmit successful
Changed Channel to
Yes ... this is just to show what's happen for rec/trans informations
gapi wrote: What mode is required if any for the TX to be in.
Thanks.
But? You have more than probably a window with the emulator screen ...?No?
Last edit: 24 Feb 2013 15:51 by domcars0.
24 Feb 2013 18:41 - 24 Feb 2013 18:41 #6976 by gapi
Thanks,
Yes have a DOS screen and a Emulator, Black & White just like the Devo 10. But have no idea how to navigate in it.
I keep asking if the TX is required to be connected and to be powered up and if so in what mode but cannot get the info.
I also need a keystroke legend I guess.
And a Tylenol, Heh!
Last edit: 24 Feb 2013 18:41 by gapi.
24 Feb 2013 18:51 - 24 Feb 2013 18:54 #6977 by sbstnp
Replied by sbstnp on topic Need EMU How To Use
Keys:
General navigation:
Enter/Return: open menu, select things on screen (same as ENT on TX)
ESC: go back, abort (similar to EXT on TX)
Arrow keys: similar to UP/DOWN and LEFT/RIGHT on TX
\ (backslash): Exit emulator
Channels +/- (values go +10/-10 each press)
q/a: elevator
w/s: rudder
e/d: throttle
r/f: aileron
t/g: AUX4 knob
y/h: AUX5 knob
Switches:
z: gear switch
x: RUD DR switch
c: ELE DR switch
v: AIL DR switch
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 24 Feb 2013 18:54 by sbstnp.
24 Feb 2013 18:53 - 24 Feb 2013 18:55 #6978 by blackmoon
Replied by blackmoon on topic Need EMU How To Use
Transmitter do not need to be connected to use the emulator.
In the manual for devo you have a section with the navigation keys, and more.
sbstnp was faster :-)
Last edit: 24 Feb 2013 18:55 by blackmoon.
24 Feb 2013 19:44 #6981 by gapi
OK, We are moving forward a little. Mercy!
1.) No TX power or connection required. Thought so but had to ask.
2.) Why I asked the above is because of the non responsiveness of the EMU on my PC.
I just found its required to "Run As Administrator" for it to respond, at my house anyways.
Still fumbling but really want the color & mouse pointer version so I trudge onward, THANKS!
24 Feb 2013 21:23 #6995 by domcars0
Please, don't forget to read the manual :whistle:
24 Feb 2013 21:43 #6997 by Hexperience
gapi wrote: OK, We are moving forward a little. Mercy!
Then use the devo8 emulator. The emulator is an exact copy of the tx. The devo10 has no color or touch screen.
24 Feb 2013 23:28 #7000 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Need EMU How To Use
domcars0 wrote: Please, don't forget to read the manual :whistle:
I must say though that these key controls are tucked far away in said manual, and searching here doesn't come up with any instructions; maybe the EMU section of the manual could be split out / duplicated in it's own little instruction manual, so it's easy to find? For a newcomer, it's not very intuitive to find the instructions on how to run the emu, and even then the list of keys/commands doesn't at first make sense.
Maybe it needs a quick intro text, saying something along the lines of "Left column = keyboard key, right column = coresponding TX switch / stick". And maybe the first column for "channels" should be split into two, "Up" and "Down"?
25 Feb 2013 00:13 #7001 by gapi
Thanks guys. I'm doing much better now. I am using the Devo 8 EMU and can see a light at the end of the tunnel.
I confess a major hurdle was the "Run as Administrator" requirement on my machine. If I had caught on sooner much less key strokes would have been made here.
I understand the "Use the manual" thing and rarely hear it here but respect it all the same. I have been using forums since the days of news groups and the Gateway 286 PC. I'm not thin skinned so fire at will.
I use the "Ctrl+F" combo in documents and Webb sites alot and sometimes it works and sometimes not but I do try.
All of you have shown patience of the saints.
  • rbe2012
  • rbe2012's Avatar
25 Feb 2013 06:45 - 25 Feb 2013 06:46 #7016 by rbe2012
Replied by rbe2012 on topic Need EMU How To Use
RoGuE_StreaK wrote: saying something along the lines of "Left column = keyboard key, right column = coresponding TX switch / stick".
I have extended the labels for emu_devo8 in this way a while ago for testing. If you are able to build your own version, I could send you the diff file. Or maybe I can build the emu_devo8-2.1.1 (last official version) with this extension.
And the keys for trimming the channels... space runs out fast...
As a hint: the analog inputs are in the keyboard rows which starts with "q" (up) and "a" (down), from left to right. The trims use the same letters, but capitalized. The switches are in the "y"-row (all for English keyboard).
Last edit: 25 Feb 2013 06:46 by rbe2012.
25 Feb 2013 08:00 #7019 by RoGuE_StreaK
Yeah I figured it out, but first glance of the manual isn't very self-explanatory; I was suggesting some wording changes and intro text for the manual itself, not necessarily in the EMU.
26 May 2013 22:15 #10328 by sfcsoup
Replied by sfcsoup on topic Need EMU How To Use
I have downloaded all the files according to posts on this site. However I do not get all the screens per the following post.
i1174.photobucket.com/albums/r603/2thero...re-2_zps49e9d252.jpg :dry:
For some reason I cannot copy and paste the screen shot but it was posted by GAPI on this thread. :S
All I get are the USB screen and DOS screen. What am I missing?
So far I have been able to figure out a lot of my questions from reading the posts. I got my MODE 1 - MODE 2 fixed, and a few other things. But this EMU just does not want to work for me the way it sounds like it should work. :(
27 May 2013 03:57 #10333 by vlad_vy
Replied by vlad_vy on topic Need EMU How To Use
You need put filesystem to folder with emulator.
deviation-emu_your_tx.exe
filesystem\your tx\
Time to create page: 0.894 seconds
