Need EMU How To Use
  • rbe2012
  • rbe2012's Avatar
27 May 2013 07:15 #10336 by rbe2012
Replied by rbe2012 on topic Need EMU How To Use
filesystem/devo10 for Devo7e and Devo10
filesystem/devo8 for Devo6(S), 8(S) and 12(S)
27 May 2013 14:21 #10345 by sfcsoup
Replied by sfcsoup on topic Need EMU How To Use
This is what I have in my DEVO EMU folder:
Language (folder)
Media (folder)
Modelico (folder)
Models (folder)
Template (folder)
Deviation-emu_devo10-v3.0.0 (exe)
Errors (text doc)
Libportaudio-2.dll
So how do I get the two color screens on the right like gapi shows on his post? :oops:
27 May 2013 14:27 #10346 by sfcsoup
Why am I using filesystem/devo8 for Devo6(S), 8(S) and 12(S) and not the Devo10 filesystem? :S
06 Jun 2013 03:30 #10624 by Kdean
Replied by Kdean on topic Need EMU How To Use
Trying to open the emu for devo 12 it is asking for a dll file???
libgcc_s_dw2-1.dll is missing
06 Jun 2013 03:46 #10626 by vlad_vy
06 Jun 2013 04:07 #10627 by Kdean
Thanks, i'll have to give it another try tomorrow.
06 Jun 2013 21:41 #10656 by Kdean
I put the three dll files in the folder with the emu and tried many combinations of devo file systems, but all i get is a black screen and the data stream screen showing it cant locate alot of stuff. At one point i would get the model icon and a layout screen, but the back ground remains black and i can only shift from box to box with the arrow keys.
I also use "run as admin" but same results.
What im i doing wrong?
06 Jun 2013 22:31 #10658 by Kdean
Here are some images
  • Raimili
  • Raimili's Avatar
  • DEVO 12S "Slope-Gliders" wellcome
07 Jun 2013 01:31 #10660 by Raimili
Replied by Raimili on topic Need EMU How To Use
Hi togehther,
I have exactly the same problem like Kdean.
Could anyone put the complete (working) EMU folder in a zip?
Let´s try...
...(hoping that anyone creates a simple Mixer GUI (Sailplane) for noopes like me)
07 Jun 2013 05:22 #10664 by vlad_vy
Replied by vlad_vy on topic Need EMU How To Use
You need place filesystem for emulator at:
filesystem\Devo10 (for Devo 7e and Devo 10)
filesystem\Devo8 (for Devo 6, Devo 8, Devo12)
  • rbe2012
  • rbe2012's Avatar
07 Jun 2013 05:32 - 07 Jun 2013 06:17 #10665 by rbe2012
For the emulator you must have a special directory structure. Where the emu_devoXX.exe is, create a folder "filesystem" and inside a directory "devo8" (Devo12 uses devo8-filestructure).
Put the media, models, language... directories in this, so you have something looking like:
-"your start directory"
  L_emu_devo12.exe
  L_filesystem
    L_devo8
      L_media
      L_models
      I L_default.ini
      I L_model1.ini
      I L_...
      L_modelico
      L_language
      L_template
      L_tx.ini
I have described this structure now for the fourth or fifth time... When I find some spare time I will write an easy description for the emus (on one page or so) which can be placed in the HowTo section or together with the manuals... or exists a volunteer out there?
Last edit: 07 Jun 2013 06:17 by rbe2012.
07 Jun 2013 07:23 #10671 by Kdean
I dont see a "media" folder in my filesys???
Could this be why it can not locate alot of things?
What comes in a media file?
Ive unziped some of the down loads and i get a "deviation-devo12-v3.0.0-e610f6.dfu"
Then another file to unzip that gives me "devo12.elf"
Are these for updateing the tx only?
The devo12-fs-58a768 that i downloaded gives me a "devo12-lib.dfu" and the filesystem folder that has no "media" folder in it.
  • rbe2012
  • rbe2012's Avatar
07 Jun 2013 09:09 #10674 by rbe2012
Sorry, I have my Devo12 only for a few days yet and I'm used to Devo8.
Devo12 has no media directory. There is some space limitation and that is the reason why for the Devo12 the library (contains the media dir) is necessary. But I believe the emulator will use this directory too (haven't tested yet, but it uses the Devo8-filesystem what contains the media dir).
08 Jun 2013 03:23 #10707 by Kdean
I still need help getting this emu to work for the 12s file system.
08 Jun 2013 04:29 #10710 by ave1
Replied by ave1 on topic Need EMU How To Use
try this
08 Jun 2013 05:09 #10711 by Kdean
ave1 wrote: try this
No, that did'nt work??????
08 Jun 2013 15:15 #10720 by ave1
Extract the zip file to a folder on your desktop or? Then run the file emu_devo12.exe. I have re-tried this (re-tested) this zip and it works fine, here. Contained inside that zip are the latest test from RBE2012/others and it really does work well on this computer.
08 Jun 2013 15:32 #10721 by ave1
This forum has blocked the Zip due to size limitations, I suppose, I am trying to send to you. If you will provide me your email address, I will happily send it to you but, outside this forum and it's size restrictions.. This zip should allow you to use the EMU with the latest developments from RBE2012.
Did you get the first zip I sent via this forum, the one you said did not work?
I'll try sending it again but...........
it should be attached here but, if no, send your address please and Ill get it (the EMU zip) over to you right away.
08 Jun 2013 15:37 #10722 by Kdean
No i did not get the first one. It never showed in the post.
My email is This email address is being protected from spambots. You need JavaScript enabled to view it.
Thank you.
08 Jun 2013 16:07 #10723 by ave1
Do you still need help with the 12S EMU?
The zip I made is too large to send via the forum. If you will send me your email address or, write to me, This email address is being protected from spambots. You need JavaScript enabled to view it., I will reply and, send a zip for the Devo12S containing what I believe to be and, is the latest progress from RBE2012, others..
Time to create page: 0.679 seconds
