DEVO 8 Telemetry Check
- clearprop88
03 Mar 2013 00:07 #7233
by clearprop88
DEVO 8 Telemetry Check was created by clearprop88
I just installed the Telemetry module in my Devo 8, but the Tlm screen says that Telemetry is not supported.
How can I check to see if the Tlm module is working?
03 Mar 2013 02:06 #7241
Replied by PhracturedBlue on topic DEVO 8 Telemetry Check
In the model menu, click the protocol button to enter proto config mode. Now turn on the telemetry. For the Devo protocol, it defaults to on (even if you don't have the module).
- clearprop88
03 Mar 2013 02:21 #7247
by clearprop88
Replied by clearprop88 on topic DEVO 8 Telemetry Check
Does telemetry only work in Devo mode?
When I select the other protocols it doesn't give me the option to turn on telemetry, only in Devo mode.
03 Mar 2013 02:24 #7249
and DSM2/X (assuming you are using nightlies)
- clearprop88
03 Mar 2013 02:28 - 03 Mar 2013 02:57 #7251
by clearprop88
I haven't been using nightlies, but I probably should start using them.
OK. Devo, and DSM2/X for now.
Will any other protocols be added later for tlm?
Most of my config's use 2801.
If I want to use telemetry in DSM mode do I have to have a Spectrum Tlm unit in the heli?
Last edit: 03 Mar 2013 02:57 by clearprop88.
03 Mar 2013 03:46 #7257
I don't have any rx that support telemetry on the 2801 so I have no way to transmit anytelemetry. Additionally I don't actually own a 2801 Tx, so I have no way to see what is being transmitted.
- clearprop88
03 Mar 2013 04:59 #7259
by clearprop88
Thanks PB.
It seems like the best way to go for now is either with Devo, or Spectrum telemetry.
03 Mar 2013 10:56 - 03 Mar 2013 18:59 #7277
Replied by FDR on topic DEVO 8 Telemetry Check
The 2801 doesn't support telemetry.
Neither pre-devo Walkera does...
Last edit: 03 Mar 2013 18:59 by FDR.
- clearprop88
03 Mar 2013 17:33 - 03 Mar 2013 17:40 #7293
by clearprop88
Are there any other supported choices for telemetry?
Last edit: 03 Mar 2013 17:40 by clearprop88.
03 Mar 2013 19:18 #7294
Yep, DSM2 and DSMX, but only in the nightly builds...
- Hexperience
03 Mar 2013 20:28 - 03 Mar 2013 20:29 #7296
by Hexperience
Replied by Hexperience on topic DEVO 8 Telemetry Check
Hopefully sometime down the road we'll have FrSky telemetry as well, but it will involve installing a chip.
Last edit: 03 Mar 2013 20:29 by Hexperience.
- clearprop88
03 Mar 2013 21:12 #7299
by clearprop88
Yes, I'm looking forward to that.
Time to create page: 1.267 seconds
- DEVO 8 Telemetry Check
