Deviation first-timer, advice needed
- TucsonFlyer
18 Mar 2013 15:59 #7887
by TucsonFlyer
Deviation first-timer, advice needed was created by TucsonFlyer
Hi all,
A few of you might recognize me from the RCg or HF boards. I'm in the middle of a new Gaui X4 build and I want to take advantage of deviation to handle my AR7200bx+sat for my new bird.
I'm looking for a bit of advice about DSMx vs DSM2 in deviation. I know DSMx support is only in the nightly builds thus far whereas DSM2 is in the 2.1.1 stable.
First off, do DSMx RX's consistently fall back to DSM2 if I were to try and bind in DSM2 mode (using 2.1.1)? Are there any significant disadvantages?
Second, am I reading things right in that the DSMx support in the nightly builds is in good shape? Should I just go with the nightly build and DSMx? Am I worrying about nothing and just being a bit paranoid?
Thanks in advance!
Thanks in advance!
- Joshua
18 Mar 2013 16:25 #7888
by Joshua
I fly my Blade 300X with DSMx and the nightly builds without any problems.
I think, Deviation 3.0 build will comming soon.
ciao, Bernd
Replied by Joshua on topic Deviation first-timer, advice needed
TucsonFlyer wrote: Second, am I reading things right in that the DSMx support in the nightly builds is in good shape?
ciao, Bernd
- sbstnp
18 Mar 2013 17:54 #7891
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Deviation first-timer, advice needed
I am flying a Parkzone T-28 with DSMX no problems so far. No heli with DSMX unfortunately.
Devo 10 + 4in1
18 Mar 2013 18:54 #7893
Replied by rbe2012 on topic Deviation first-timer, advice needed
I also have no problems with Blade mQX, Nano CP and mCP X BL, all with DSMx.
- TucsonFlyer
18 Mar 2013 19:56 #7900
by TucsonFlyer
Replied by TucsonFlyer on topic Deviation first-timer, advice needed
Ok, sounds like good news!
I think I'll just go with the nightly build and go from there.
One more question, I've got a 3GX on another heli and it needs a 120* swash setting (Devo 8S). Will the swashmix percentages translate directly over to the deviation values or are they on different scales? Same for gyro %, expo % and subtrim values? Any sense at all in trying to replicate my current values?
I strongly suspect I'm just going to have to re-setup the heli's from scratch arn't I
- RCadik
19 Mar 2013 22:44 - 19 Mar 2013 23:07 #7930
by RCadik
Replied by RCadik on topic Deviation first-timer, advice needed
Range tested and flying a F450 Quad with KK2 FC, AR600, (DSMX) & Enigma 3D with AR8000, using a 12S with Widescreen firmware & RTC.
No problems or issues, other than the tool mounted on my shoulders. :
My THANKS, go out to the development gang! Looking forward to 3.0.
Last edit: 19 Mar 2013 23:07 by RCadik. Reason: error
- TucsonFlyer
19 Mar 2013 22:50 #7931
by TucsonFlyer
Bah, just found the FBL setup sticky. That'll teach me to RTFM:
Good to hear that everyone seems to be doing fine with DSMX! I just replaced the RX802 on my 250 with a DSMX sat so it'll be my first heli to fly on deviation as soon as I can find the time to sit down and set it all up.
If your heli manual uses 0%-100% you will need to convert those to -100 to +100 values.
Time to create page: 0.090 seconds
- Deviation first-timer, advice needed
