Devo10 and rx1002 bind problems
05 Jun 2013 03:05 #10578 by Pianobill1
Devo10 and rx1002 bind problems was created by Pianobill1
Hey guys...hope this is the right place to post this message..
Recent newbie to Deviation.....and love what I see.
My problem is binding tx to rx. If I flash with Deviation, tx and rx will not bind. If I flash back to Walkera firmware, all works. I have read numerous posts on how to rebind rx1002. Insert the bind plug into power input on rx, connect power to an aux channel, wait for slow blinking light. Then perform reinit on tx. From what I am seeing it is clearing the code in the rx. But will not bind under Deviation. The instant I flash walkera code it starts working. It appears that Deviation is preventing binding.....
What am I doing wrong?
Thanks for the help
05 Jun 2013 03:12 #10580 by PhracturedBlue
Replied by PhracturedBlue on topic Devo10 and rx1002 bind problems
on the rx1002 you insert the bind plug (I don't recall which port..probably battery), power on the rx, power off the Rx, unplug the bind plug.
Then power on the Tx, make sure it is set to 'Devo' protocol with ID set to None. Then power off the Tx. Now power on the Rx and then Power on teh Tx. It should say 'Binding' and should bind within 20 seconds.
05 Jun 2013 03:13 #10581 by PhracturedBlue
With Walkera firmware installed, check the settings and make sure you do NOT have a fixedID set. If you do, then you haven't properly cleared it from the Rx yet. You should make sure you can bind the Rx with Walkera firmware without a fixedID 1st.
05 Jun 2013 03:39 #10582 by Pianobill1
Replied by Pianobill1 on topic Devo10 and rx1002 bind problems
Thank you so much sir!!!
I am happy to announce it is now working...very excited.
I see what I "was not doing"..... Clearing out the code. I did not clear out the code on the tx. I kept it at DEVO, Re -Init and None.... But there was still a code in the tx. Once I erased/deleted the code and powered up the tx, as you said...it would auto bind within a few seconds.
Very glad I am up and running.
Thanks PB
02 Jun 2015 11:01 #33356 by mart123
Replied by mart123 on topic Devo10 and rx1002 bind problems
hey Pianobill1, do you have the walkera firmware to post...I need to flash back.
regards mart
06 Jun 2015 21:41 #33561 by The Deviator
16 Jun 2015 03:57 #34155 by ShawnecJP
Replied by ShawnecJP on topic Devo10 and rx1002 bind problems
How did you erase the code or select "none"?
I'm trying to do that now and I'm not given the option to do that....
Very frustrating....
16 Jun 2015 05:14 - 16 Jun 2015 06:07 #34160 by vlad_vy
Replied by vlad_vy on topic Devo10 and rx1002 bind problems
Select Fixed ID, press ENT, select DEL and press ENT several times, select DONE and press ENT. Now you have Fixed ID = NONE.
Last edit: 16 Jun 2015 06:07 by vlad_vy.
16 Jun 2015 06:05 #34165 by ShawnecJP
My problem was that I was on the wrong line before I scrolled across to delete... I thought I couldn't select the DEL button but I just had to be on the second from the bottom line to move over there ....
I feel like an idiot
Thanks for the help!
06 Sep 2015 19:31 #37506 by breonsnow
Replied by breonsnow on topic Devo10 and rx1002 bind problems
vlad_vy wrote: Select Fixed ID, press ENT, select DEL and press ENT several times, select DONE and press ENT. Now you have Fixed ID = NONE.
Hi Guys, sorry to post on this old thread. I am helping my old man get this quad over to the deviation firmware on his Devo10 and we are having this issue, I delete the fixed id hit DONE come out and try bind...no noy! but if I go right back into the fixed Id the number I just deleted is still there??
Any ideas... or am I missing something out?
Cheers in advance! Breon
06 Sep 2015 19:37 #37507 by mwm
Replied by mwm on topic Devo10 and rx1002 bind problems
What version of deviation are you running? That will matter.
Current builds generate a random id if you try and change the id and it was empty, which you might be seeing. They also change the "Bind' button to "Re-init" when there is no bind id. You might check that.
06 Sep 2015 20:20 #37512 by breonsnow
Thanks so much for the quick responce.
Its the lastest firmware "deviation-devo10-v4.0.1"
Yes it does seem like it is randomly setting one, and yes the bind option changes to "Re-init" - is this all positive? I just cant get them to bind - thanks again so much!
06 Sep 2015 21:04 #37514 by mwm
You didn't say, but I assume because of the topic that you're using an rx1002, or at least some form of walkera rx. If not, what are you using?
The Walkera Rx's won't bind if they are bound to a fixed ID. You have to clear the ID from them. Have you done that?
06 Sep 2015 21:11 #37515 by breonsnow
Sorry, I will have to find out what the rx is (sorry, its at work - I will have a look tomorrow)
I have tried to clear the ID but as I said it just keeps setting an ID even after I delete it...
I will get th rx make tomorrow and hopefully that will help! THANK you so much for your help!
06 Sep 2015 21:14 #37516 by mwm
Sorry I wasn't clear. You have to clear the ID on the Rx, not the Fixed ID on the Tx. The only way to tell that you haven't cleared the ID is that it won't bind afterwards.
06 Sep 2015 21:25 #37517 by breonsnow
oh right, yes... we did unbind it on the rx (power up with binding plug in and then power down, remove binding plug) Red led was flashing as I think it should have been. I will give this another go tomorrow morning.
08 Sep 2015 19:02 #37574 by breonsnow
Hi MWM,
I am sorry for the delay in getting back to you - it is the rx1002 and I have finally got it bound! Followed your steps and these:
clear the code of the rx-
power on the rx
power off the Rx
Clear the code in the tx-
Power on the Tx
make sure it is set to 'Devo' protocol with ID set to None. (if there is a number in the id go and and delete)
To bind-
Now power on the Rx (i had to have the battery/esc connected to the batt port rather than a channel to get it to work.)
I think I wasnt clearing the RX properly ...so thank you SO MUCH for your help!
Cheers Breon
01 Oct 2015 20:37 #38329 by jk6stringer
Replied by jk6stringer on topic Devo10 and rx1002 bind problems
Is there a way to use the ID number to lock them? Im having a issue on my APM quad where if I engage the failsafe it doesn't rebind. With my orange Rx the rebind is not an issue.
01 Oct 2015 20:51 #38330 by jk6stringer
Found my answer in another thread.
After you do the autobind at least once as described above. Just click on fixed ID and you will see that it has some type of auto ID now entered. After you close this, it will now say BIND instead of RE-INIT.
Now Im happily turning off and on engaing my failsafe and rebinding in flight. :)
Time to create page: 0.148 seconds
