7E emulator
31 Jul 2013 17:32 - 31 Jul 2013 17:48 #12652 by EArHog
7E emulator was created by EArHog
With respect to the 7e, what's emulator? How do I use it?
(given the question, I assume there's no need to identify myself as a newbie :) )
Last edit: 31 Jul 2013 17:48 by EArHog.
31 Jul 2013 19:04 #12654 by RandMental
Replied by RandMental on topic 7E emulator
EArHog wrote: With respect to the 7e, what's emulator? How do I use it?
Best would be to start with www.deviationtx.com/user-manual/user-manual-7e-10
31 Jul 2013 19:14 #12655 by EArHog
Replied by EArHog on topic 7E emulator
I saw that. It is what stimulated the question in the first place.
31 Jul 2013 19:28 #12656 by FDR
Replied by FDR on topic 7E emulator
The emulator is a program, which you can run on your PC, and which acts exactly like the tx: you can configure models with it, which you can even upload to the tx later...
31 Jul 2013 19:56 #12665 by EArHog
FDR wrote: The emulator is a program, which you can run on your PC, and which acts exactly like the tx: you can configure models with it, which you can even upload to the tx later...
That was my presumption. I downloaded the program and opened it. Even if I could enter data into those boxes (I can't, or perhaps don't know how), how can I tell a good value from a bad value for that field?
I'm sorry if I try your patience. I will understand if I can't be helped.
31 Jul 2013 20:01 #12667 by FDR
The boxes on the right are just for debugging and testing purposes.
The emulator is shown on the left, but you probably didn't copied the filesystem to the exe's directory, so there is nothing shown. Am I right?
31 Jul 2013 20:50 #12669 by EArHog
FDR wrote: The boxes on the right are just for debugging and testing purposes.
When I open the file I get a small window, left half of which is a USB logo and the right half is 30 - 40 boxes, most have 00.00. I'm not able to enter values (which I assume is the purpose). But even if I could enter values, I don't know how to learn what a proper value looks like.
I think I need a continuing education class at the local Community College.
01 Aug 2013 05:00 #12679 by FDR
Yep, just as I thought...
Download the filesystem for the 7E too, and unzip it into the folder where the emulator is...
21 Aug 2013 03:49 #13053 by bruce356
Replied by bruce356 on topic 7E emulator
Hi also new and can not get this to work. Using Win8 x64
The manual does not explain how to actually use this emulator.
When I execute the emulator I get two windows
Command prompt with following:-
Brightness: 1
Wait Release
Released
Wait Press
The other window is a GUI, left half of which is a USB logo and the right half has 40 boxes, most have 00.00. I copied the filesystem for the 7E into the same folder:-
Layout
Media
Modelico
Models
Protocol
Templates etc.
Where to from here?
Am I supposed to connect my 7E to computer via USB?
How does this emulator actually function?
Thanks and regards - bruce
21 Aug 2013 04:18 #13055 by FDR
The filesystem is missing.
You have to unzip iz into the directory of the emulator...
21 Aug 2013 04:28 - 21 Aug 2013 04:29 #13056 by vlad_vy
Replied by vlad_vy on topic 7E emulator
Devo 7E emulator use Devo10 filesystem, or simply rename filesystem\devo7e to filesystem\devo10
emu_devo7e.exe
filesystem\devo10
Last edit: 21 Aug 2013 04:29 by vlad_vy.
21 Aug 2013 05:04 #13060 by bruce356
Thanks vlad_vy renaming to devo10 worked.
FDR as in my post I had unzipped into the exe folder but the default name devo7e is not recognised by emulator, which I did not know.
Regards - bruce
21 Aug 2013 05:23 #13061 by FDR
Sorry, I missed that...
Time to create page: 0.886 seconds
