DEVO8S + RX802 and TRex 450 Pro. HELP !
- Richard
05 Aug 2013 18:39 - 05 Aug 2013 18:42 #12776
by Richard
DEVO8S + RX802 and TRex 450 Pro. HELP ! was created by Richard
I can not program my radio to fly my helicopter.
Radio: DEVO 8S (mode 2) + RX802
Heli T-REX 450 Pro flybarred.
When I single parameter controls, they are functioning properly.
Ail operates on AIL + Chan6 (reverse),
Elev operates on Elev,
Throt operates on throttle, and
rudder operates on rudder.
But as soon as I put the cyclic parameters (3 servo 120), servo move anyhow. Elev operates on ELEV + Chan 6, AIL operates on ELEV and AIL only not on Chan 6, etc.
Only the rudder function properly.
Is it possible that there is an incompatibility with the RX802?
The "cyclic 1, 2 and 3" are they routine in the firmware? Will it a bug?
What is "cyclic 1", "2 cyclic" and "cyclic 3 ' respectively ? Pitch? Roll? Collective?
From what I'm told,
CYC-AIL operates on 2 servo : "AIL (Ch2)" and "canal6" in reverse mode,
CYC-ELE operates on 3 servo : "ELE" and "AIL" + "Chan6". If "ELE" increases, "AIL" + "Chan6" decreases a little and vice versa.
CYC-COL actuates the 3 servo identically. If UP, all servo UP.
Is this correct?
I want to understand.
Please, help me.
Thank you.
Sorry for my English but I use google translator, my English is very poor.
From what I'm told,
Is this correct?
Please, help me.
Thank you.
Last edit: 05 Aug 2013 18:42 by Richard.
05 Aug 2013 18:52 #12777
Replied by FDR on topic DEVO8S + RX802 and TRex 450 Pro. HELP !
As a starting point try to load the 6ch heli template into an empty model slot, and make sure the reverses are right...
- Richard
06 Aug 2013 09:39 #12784
by Richard
Replied by Richard on topic DEVO8S + RX802 and TRex 450 Pro. HELP !
Thanks very much !
It works !
But I have a question.
There is no 'source' for the "Chan6" except "cyclic3".
Does it say that the association "Chan6 & AIL" is made in the "cyclic3" and "cyclic2" routines ?
An other question.
Can I use the USB connection on my radio instead of training port to operate in a flight simulator?
It works !
An other question.
06 Aug 2013 10:05 #12786
The calculation also need some inputs: the pure aileron, elevator and pitch values, which are supplied to the CCPM throw three specific virtual channels: CYC-AIL, CYC-ELE and CYC-COL.
The calculation itself is a bit complex, but you can fine tune it with some simple values on the Helicopter page...
The "Cyclic1", "Cyclic2" and "Cyclic3" are the outputs (i.e. results) of the CCPM calculation. These values are sent to the appropriate channel for the swash servos.Richard wrote: But I have a question.
Only with the latest nightly builds. The v3.0.0 doesn't support it.Richard wrote: An other question.
- Richard
06 Aug 2013 10:12 #12787
by Richard
Ok I'm really just starting out and I have everything to learn.
Thank you for your time.
Time to create page: 0.686 seconds
- DEVO8S + RX802 and TRex 450 Pro. HELP !
