WOULD DEVIATION HELP
- JH
20 Sep 2013 19:19 #13936
by JH
WOULD DEVIATION HELP was created by JH
I'm using a Devo 10 to drive my hex-a-copter. On the Devo 10 there is a function called "Flight Switch" which can be assigned to one of the two 3-position switches.
But I want both 3-position switches for my camera gimbal. The programing forces me to have one of them be the "Flight Switch". I don't even understand why I need a "Flight Switch". It starts the props rotating or speeds them up if they are already rotating.
Would Deviation allow me to use those two switches for my camera gimbal and maybe not even have a "Flight Switch" or at least assign it to one of several 2-position switches I'm not using?
Thanks for any clues.
- Kdean
- domcars0
20 Sep 2013 21:06 #13944
by domcars0
Replied by domcars0 on topic WOULD DEVIATION HELP
Coffee is the only thing you can't do with deViation!
- RandMental
20 Sep 2013 21:12 #13945
by RandMental
Says who, going into TH (throttle hold switch = 1) means I stopped flying and then switches the coffee machine on.
Replied by RandMental on topic WOULD DEVIATION HELP
domcars0 wrote: Coffee is the only thing you can't do with deViation!
- JH
20 Sep 2013 21:21 #13948
by JH
Replied by JH on topic WOULD DEVIATION HELP
Thanks for the replies. I am going to install Deviation 1.7 into my Devo 10, yes (Win7)? And I should have coffee BEFORE I start, right?
- stevecox
- Keep swinging
21 Sep 2013 04:56 #13953
by stevecox
Adelaide
Replied by stevecox on topic WOULD DEVIATION HELP
You may want to fiddle with the emulator on the pc first to get familiar with the functions and setting model files up. read the manual on how to install correctly and get into this. Personally I would rather go with version 3.0 at least or rather the nightlies which currently seem quite stable.
Adelaide
21 Sep 2013 08:57 #13958
Replied by rbe2012 on topic WOULD DEVIATION HELP
I think JH meant dFuse 1.7 - might not work with Win7 in some cases (1.5 does).
I recommend to use the nightly.
JH, make sure you have your coffee ready when starting, you will have no time to cook... And when you are done, deviation will keep you awake so you don't need coffee anymore...
Time to create page: 0.799 seconds
- WOULD DEVIATION HELP
