devo 7e use for sim
- crave_07
28 Oct 2013 16:04 #15081
by crave_07
devo 7e use for sim was created by crave_07
hi guys good day... what should i need to make my devo 7e use as simulator control? do i need to buy any usb dongle to connect in my pc? i have windows vista laptop. thanks everybody.
- Khan
- Build. Crash. Repeat.
31 Oct 2013 22:34 #15178
by Khan
Replied by Khan on topic devo 7e use for sim
Hi !
Well first thing it depends on what Simulator you intend to use. Most of them will require a dongle, but on some occasion you might be able to plug directly the cable in the line in jack of your computer.
01 Nov 2013 06:30 #15186
Replied by rbe2012 on topic devo 7e use for sim
I use such a dongle with PPM out. But I know the actual deviation has a USD HID where the tx can be used like a USB joystick, but I never tried this. You can select this in the protocol section (where you will find PPM out too).
02 Nov 2013 15:37 #15249
I tried USB HID with my Devo8. It took some time to figure out how the inputs have to be assigned to the channels but it works without any problems. I used ClearView and EasyFly3.
I confess I am not sure if it is already implemented in deviation 3.0. It is included in the last nightlies and in the 3.1-beta-versions.
Time to create page: 0.521 seconds
- devo 7e use for sim
