RX1202
10 Nov 2013 09:09 #15485 by soonglim
RX1202 was created by soonglim
I just recently decided to use the RX1202 that came with my Devo 12S as I want to build a second trex 450. Unfortunately I ran into the following problem. I had setup my Devo 12S with the Devo-12-3.0.0 deviation and it's been working great for all my Walkera devo helis and Blade micros with DSM2/DSMX. But with the RX1202, the collective channel ("cyclic3") doesn't seem to be working correctly. There is no counter movement of the pitch servo when giving aileron stick input. The pitch servo moves on collective stick movement, but the other aileron and elevator servo does not move collectively. I'm using swashtype "None/1Servo".
Anyone had this issue with the RX1202 and devo 12s with the deviation software? Could this be just a bad brand new RX1202, since same/similar settings work on all my other receivers (devo and dsm2/dsmx)... only difference is the RX1202 has 12 channels instead of 7 or 8 on my other receivers.
  • rbe2012
  • rbe2012's Avatar
10 Nov 2013 11:21 - 10 Nov 2013 11:22 #15487 by rbe2012
Replied by rbe2012 on topic RX1202
Looks as if you have not selected the correct swashplate type (I guess 3 Servos 120°).
My rx1202 works fine.
Last edit: 10 Nov 2013 11:22 by rbe2012.
10 Nov 2013 12:16 #15488 by Hexperience
Replied by Hexperience on topic RX1202
Rbe is correct. It sounds like you have a normal flybar heli but when you select none or 1 servo for the swash type it means you have a flybarless controller.
10 Nov 2013 16:50 #15498 by soonglim
Replied by soonglim on topic RX1202
I actually have a flybarless. But tried selecting the other swashtypes... servos just go all over the place with the other swashtypes. Tried it with and without the flybarless unit (3gx), same behavior. But with the spektrum ar8000 it all works fine... it's dsmx and has different channel mapping though.
Rbe, would it be possible for you to post/upload your model for your rx1202 for me to try? If that doesn't work, then I must have a bad rx1202.
11 Nov 2013 03:34 #15508 by vlad_vy
Replied by vlad_vy on topic RX1202
You setup fresh model with DEVO protocol or changed old model with DSMX protocol? If second is a case, you need first remap channels manually after changing protocol. Change in mixers the source for first 4 channels.
11 Nov 2013 08:15 #15512 by soonglim
I started with fresh model. Have the following channel setup (on Mixer screen):
1-ELE         Cyclic2
2-AIL         Cyclic1
3-THR   THR   Complex
4-RUD   RUD   Expo&DR   FMODE1  FMODE2
5-GEAR        None
Ch6           Cyclic3
Ch7     MIX0  Expo&DR   MIX1    MIX2
Ch8           None
Ch9           None
Ch10          None
Ch11          None
Ch12          None
CYC-AIL  AIL  Expo&DR   FMODE1   FMODE2
CYC-ELE  ELE  Expo&DR   FMODE1   FMODE2
CYC-COL  THR  Complex
Virt4         None
Virt10        None
Spot anything that might be a problem?
  • rbe2012
  • rbe2012's Avatar
11 Nov 2013 09:56 #15517 by rbe2012
For me it's still unclear if you have only the rx1202 or additionally your fbl system 3gx installed and tested when you see the problems.
What does the manual of the fbl unit tell you about mixing? Does the unit do that? Or must it be calculated in the transmitter? If it is done twice it can have unpredictable result, even the one you described.
I actually can't send you my config, maybe later. But I have a flybar heli with mixing in the transmitter so it might not be of any use for your config.
11 Nov 2013 10:59 #15520 by soonglim
I've tested with both the 3gx connected and without, i.e., one case with the servos connected to 3gx, and one case where the servos are directly connected to the rx1202. The results are the same, the cyclic mix for collective input is not working for the rx1202. Doing same experiment with ar8000 (again with one case where servos are connected to 3gx, and another case where servos are connected to ar8000), both cases works as expected.
It seems the rx1202 doesn't do any collective mixing, while other receivers do. I even tried to copy my tx setting for my walkera v120d02s (since both are devo protocol), then bind with the rx1202. Again, what worked on the v120d02s receiver did not work for the rx1202 - the collective mix is not correct for the rx1202.
Is using ch6 for Cyclic3 and CYC-COL virtual channel is Cyclic3, correct for the rx1202? And for CYC-COL, using THR as source is also correct? Are there different modes for the rx1202 where it doesn't do mixing? But if the rx1202 doesn't do mixing, then the tx settings I have on the devo 12s should be doing it, right?
11 Nov 2013 11:14 - 11 Nov 2013 11:14 #15521 by FDR
Replied by FDR on topic RX1202
soonglim wrote: It seems the rx1202 doesn't do any collective mixing, while other receivers do.
No, of course it doesn't do CPPM. Neither Walkera bare receiver does...
The one in the V120D02 has an inbuilt FBL controller too, so it does.
Could you post your model config file for checking if there is something wrong?
Last edit: 11 Nov 2013 11:14 by FDR.
12 Nov 2013 05:29 #15536 by soonglim
From all the feedback and suggestions, I went back and started from scratch and reviewed my mixes and swashtypes, and as I tried the different swashtypes, now noticed a pattern - the Aileron and Elevator cyclics are swapped for "None/1Servo" and "120" swashtypes, different from the other swashtypes and also different from other devo receivers I have. Thus swapping the wire connections for Aileron and Elevator servos on the rx1202 works - or swap the cyclic mapping on the mixer for Aileron and Elevator also works.
I now have the model settings working perfectly with the rx1202 receiver for my trex 450. Using 3gx fbl controller also now works with it. (Also tried my microbeast fbl controller and it's perfect).
Here's my working mappings using "120" swashtype, on the mixer screen:
1-ELE         Cyclic1
!2-AIL        Cyclic2
3-THR   THR   Complex
5-GEAR        None
Ch6           Cyclic3
Ch8           None
Ch12          None
CYC-COL  THR  Complex
Virt4         None
Virt10        None
Attached is my model setting for reference if anyone else ran into same as I did. Thanks for everyone's replies, it helped me a lot to get to a working solution.
File Attachment:
File Name: model16.ini
File Size:4 KB
12 Nov 2013 06:03 #15537 by FDR
Great!
However there are a few mistakes:
- the FMODE1 switch is missing from the second throttle page;
- the rudder (and only the rudder) has failsafe set to zero. Is that intentional?
12 Nov 2013 06:20 #15538 by soonglim
The other parameters still needs to get dialed in and corrected. I was just mainly getting the cyclic stuff working.
Time to create page: 0.297 seconds
