EMU .elf file
25 Nov 2013 17:56 #15810 by ave1
EMU .elf file was created by ave1
Can someone share how to use this file. I assume it is essential for utilizing the emulator but, I have never known how to use an .elf file and plug in into the exe.. RBE was thoughtful and always helpful but, I don't wish to distract. So, I have downloaded the file but, not sure how to proceed using the emulator as it is an executable.
25 Nov 2013 18:22 - 25 Nov 2013 20:24 #15811 by SadSack
Replied by SadSack on topic EMU .elf file
Not needed for Emu. Only needed when you have a problem with your Tx and asked for error.txt+elf's. So when you compile you nightly for example you'll have elf's and DFU's but you only need DFU's.
whopps :-)
Last edit: 25 Nov 2013 20:24 by SadSack.
  • rbe2012
  • rbe2012's Avatar
25 Nov 2013 19:11 #15812 by rbe2012
Replied by rbe2012 on topic EMU .elf file
When you compile with linux the emulators are *.elf files and are executable. Sorry, I wanted to upload the Windows versions but mixed it up...
Now you will find the Windows emulators.
Time to create page: 0.034 seconds
