Changing Models
- MakDaddy
26 Nov 2013 14:09 - 26 Nov 2013 14:10 #15851
by MakDaddy
Changing Models was created by MakDaddy
This is just a minor complaint, if one could call it that, or rather it would be an enhancement. The more I use deviation the more I like it.
I was wondering if in the future, the ability to change models without having to click down into the menus.
Not that this is a big thing, it sometimes takes multiple clicks to change models. Wish there was a shortcut key or key combo to access it easier. Or is there?
Last edit: 26 Nov 2013 14:10 by MakDaddy.
26 Nov 2013 14:23 #15852
Replied by FDR on topic Changing Models
You are talking about the DEVO 10 or 7E I suppose...
On the others you click on the name and select an other from the list.
- MakDaddy
26 Nov 2013 15:37 - 26 Nov 2013 15:40 #15858
by MakDaddy
Replied by MakDaddy on topic Changing Models
Yes I have a Devo 10. Is it just the nature of the transmitter interface then?
The Devo 10 requires you to go to the model menu and find "load" then select the module you wish to use.
Last edit: 26 Nov 2013 15:40 by MakDaddy.
26 Nov 2013 15:41 - 26 Nov 2013 15:44 #15859
Yes, I guess.
However I agree, that it could be easier...
EDIT: I would definitely put that option into the main menu too...
Last edit: 26 Nov 2013 15:44 by FDR.
- kreidler
26 Nov 2013 18:35 #15870
by kreidler
Replied by kreidler on topic Changing Models
But You know the option to define the 'Model setup' as a menu on the "Main page config"?
If you define 'Model setup' as the last item of the four menus the access will be via a long-press 'DN' directly to the 'Model Setup' page. One 'ENT' and you can choose the model you like.
26 Nov 2013 19:14 #15874
Yep, that's not too many clicks either...
You have to step throw the list, which is much more anyway...
27 Nov 2013 12:31 #15923
Replied by rbe2012 on topic Changing Models
I have looked into the code because I had the idea of integrating the model selection in the quick pages, but this is no easy task because although it looks like an extra page it is internally not defined as such and so not usable as a quickpage target.
27 Nov 2013 14:44 - 27 Nov 2013 15:54 #15926
Replied by PhracturedBlue on topic Changing Models
Rbe,
I think you could solve that by defining a new 'page' which is never actually linked into the menus but is available from the quick-pages list. Then have that page call the listbox.
Alternatively we could special-case the 'Load' case on the quick-pages, or even just add it as the 1st item in the menu. It is a reasonable request on the Devo10/7e since you cant get there from the main page.
Last edit: 27 Nov 2013 15:54 by PhracturedBlue.
27 Nov 2013 14:51 #15928
I would put it into the main menu as 1st, however my vote doesn't count too much, because I don't have a 10 nor 7E...
- MakDaddy
28 Nov 2013 15:07 - 28 Nov 2013 15:21 #15970
by MakDaddy
I would be wonderful to have it on the first page (main) as first option as FDR noted, similar to what is used on the 9x w/er9x . Not that this is a major deal, but when you get 10 or more different models, there is a lot of button pressing to change models.
Thanks for looking into this guys.
Also while I have your attention
... I noticed when using a multiple rate setup, especially with elevons, you have to go through each channel or page, (in this instance 6 of them for each channel), and to add/change expo you have to edit each page. This requires changing 12 settings and saving each one. Again not a big deal as this can be done easier using wordpad++ but at the field it can take a while. Is it possible to put an expo selection for instance channel 2 Ail (left side) where you can reverse, change rates etc.. and put the expo there so one setting would apply to all? Just a thought or am I missing something that makes it easier?
Last edit: 28 Nov 2013 15:21 by MakDaddy.
28 Nov 2013 15:32 #15972
Have you tried using a virtual channel for this? Take you input stick as channel input, make a curve 1:1 and use the output where you formerly used the stick. Then you can change the 1:1-curve to anything else and are done.
- MakDaddy
28 Nov 2013 17:04 #15988
by MakDaddy
RBE,
I have not tried virtual channel setup (I am still new to Deviation), the Elevon setup I used was in the template area from the Deviation forum. I will look into it. Thanks!
- MakDaddy
06 Jan 2014 02:15 #18034
by MakDaddy
It has been a while since I mentioned an easier way to change models.
Is this something that can be incorporated in a future build?
- WheresWaldo
06 Jan 2014 03:03 - 06 Jan 2014 03:03 #18036
by WheresWaldo
Replied by WheresWaldo on topic Changing Models
MakDaddy, with 4.0.x you can change the Main page config > menu 1 to be Model setup. With it set like that a long down press goes directly to model setup.
If you don't want it to be the first page on a long down press then make it Menu 2 or 3 or 4.
Last edit: 06 Jan 2014 03:03 by WheresWaldo.
- MakDaddy
06 Jan 2014 16:16 #18083
by MakDaddy
I have not updated to 4.0x yet. Did not know this feature was enabled.
Thanks WheresWaldo!
Thanks WheresWaldo!
06 Jan 2014 16:29 #18085
This feature is called "quickpages". I always believed it was there since the beginning...
- WheresWaldo
06 Jan 2014 16:35 #18086
by WheresWaldo
Yes but I don't think "Model setup" was there until you enabled it in 3.1.0
- Changing Models
