Devo 8 training master mode
- Flo38
02 Dec 2013 17:16 #16190
by Flo38
Devo 8 training master mode was created by Flo38
Hi everybody,
I'am currently trying to help someone to begin model flying.
As I don't find a trainer capability on the original devo 8 radio, I would like to know whether it is possible on the deviation protocol ?
I read a topic about using a deviation devo 8 as a slave, but here I would want it to be a master for a dx4e.
Thank you really much
- domcars0
02 Dec 2013 20:45 #16193
by domcars0
Replied by domcars0 on topic Devo 8 training master mode
I think you need to install the Nigthly Build release.
- Flo38
03 Dec 2013 11:55 #16222
by Flo38
Replied by Flo38 on topic Devo 8 training master mode
Ok so I guess this means nobody tried ?
- BitOne
03 Dec 2013 13:33 - 03 Dec 2013 21:41 #16225
by BitOne
Replied by BitOne on topic Devo 8 training master mode
I use a DX5e as a slave of a Devo8S (and not DX8S as previously said
). It works well.
Should be quite similar to the DX4e.
Last edit: 03 Dec 2013 21:41 by BitOne. Reason: Wrong TX name
03 Dec 2013 13:58 #16229
Replied by PhracturedBlue on topic Devo 8 training master mode
I assume BitOne meant Devo8S not DX8S.
Deviation does support master mode, but only in the nightly builds. Someone should probably set up a howto tutorial for this.
- BitOne
03 Dec 2013 21:40 #16246
by BitOne
Yes you're right, sorry for the mixup, I was meaning Devo8S...
- Flo38
06 Dec 2013 13:36 #16322
by Flo38
Ok, I guess I will have to wait if I want it in the original version
Thank you
Thank you
06 Dec 2013 14:28 #16327
Replied by FDR on topic Devo 8 training master mode
The original Walkera fw can act as a master too, but then the channel order is fixed to EATR, which might be different on the trainee's tx.
If you mean the released deviation version under "original", then yes, you have to wait some more...
- Flo38
07 Dec 2013 17:17 #16378
by Flo38
Yes, I meant deviation 3.0 or after because apparently it is not compliant with this one.
Maybe I should ask a question to understand what the nightly build is. In my opinion it is a currently tested version, which should lead to functionnal options once they are validated.
Am I wrong somewhere ?
- WheresWaldo
07 Dec 2013 17:39 #16379
by WheresWaldo
Replied by WheresWaldo on topic Devo 8 training master mode
Yes the nightly versions are "under-development" versions that are built when changes are made, usually. That may not necessarily mean every night.
From my reading of FB posts, he only allows commits of stuff that actually works and does not cause any new issues to crop up in his repository. If you build your own from his or ask someone to build it for you, you can play with all the new or fixed features and pretty much have a "finished" versions as of that particular date.
This could also help those developing just in case the rare bug does slip in and then it can be reported. The small active group does not know everything about how DeviationTX is used and we all learn something new nearly every day.
- Flo38
08 Dec 2013 09:25 #16398
by Flo38
OK, thank you for this good answer
- Hexperience
08 Dec 2013 14:54 #16404
by Hexperience
Replied by Hexperience on topic Devo 8 training master mode
Well,my devo12 is still not working correctly after fresh install and fresh settings in phoenix.
Time to create page: 0.373 seconds
- Devo 8 training master mode
