Walkera RX2613-V with v100D01 ?
21 Jan 2014 22:03 #18874 by bmwbiker
Walkera RX2613-V with v100D01 ? was created by bmwbiker
I have a problem to run WK V100D01 with the RX2613V usinng an Devo8s with Deviation 4.01
In some forums people report(but at about 2-3 years back) that they run my components well with WK2801.
My problem is, that the tail-rotor starts running at zero-Throttle and stops at about 10% throttle while the main-rotor starts movingat 8% Throttle.
has anybody an solution to keep this setup running correct?
Thanks in advance for fast response,
bmwbiker
21 Jan 2014 22:38 - 21 Jan 2014 23:46 #18878 by Tom Z
Replied by Tom Z on topic Walkera RX2613-V with v100D01 ?
I had the Walkera V100D01 and it worked great with my WK2801-Pro.
You have to run it in COMPTB 2401 mode with the WK2801-Pro.
On your Deviation you need to have Protocol=WK2401
I have a couple models for the Walkera V100D01 if you want to try one.
deviationtx.com/forum/model-configs/2555...nd-quad-models#17995
Last edit: 21 Jan 2014 23:46 by Tom Z.
Time to create page: 0.295 seconds
