My first experience utilizing the advanced mixer
01 Feb 2014 06:22 #19564 by Tom Z
I am not familiar with "Copy to". Not sure what it does either...
One more thing. On the model you posted 19552 (model23.ini) the Throttle Hold
on RUD DR1 I set was disabled. Do you have a working throttle hold and if so how did you do it as I don't see it anywhere.
01 Feb 2014 06:26 #19565 by ave1
throttle safety set it to Hold 1
01 Feb 2014 06:27 - 01 Feb 2014 06:28 #19566 by sbstnp
Tom Z wrote: I am not familiar with "Copy to". Not sure what it does either...
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 01 Feb 2014 06:28 by sbstnp.
01 Feb 2014 06:30 #19567 by ave1
over write stuff, yes it does. Learned that one the hard way.
Thanks for helping
01 Feb 2014 06:53 #19568 by Tom Z
ave1 wrote: throttle safety set it to Hold 1
I still don't see this anywhere...
Can you tell me where to look?
Maybe the setting wasn't saved to the file when you exported it out of the transmitter.
01 Feb 2014 06:59 #19569 by ave1
try this one
01 Feb 2014 07:09 #19570 by Tom Z
No luck with that one either...
I can't see any throttle hold in the last two models you posted.
If TH is working for you it must be in the model file somewhere.
Where is the setting at that you did this "throttle safety set it to Hold 1"
01 Feb 2014 07:16 #19571 by Tom Z
OK here is the TH but it is not showing up in my emulator for some reason.
Might have to post for help on this one.
Here is TH in the ini file.
[channel3]
safetysw=HOLD1
safetyval=-100
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=5point
points=-100,-20,20,70,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=5point
points=100,80,60,80,100
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=5point
And here you don't see it in my emulator.
01 Feb 2014 07:16 #19572 by ave1
I just checked it to confirm it is indeed working. Yes, it is.
1) I went to ch 3 on mixer page (on the far left)
2) highlighted same
3) safety changed to HOLD1 (this is all I changed)
4) you already had value set to -100
01 Feb 2014 07:18 #19573 by ave1
It is the page of the screen shot above.
safety set to HOLD1 and Safe value set to -100
01 Feb 2014 07:18 #19574 by Tom Z
We posted at the same time. See my post above yours.
01 Feb 2014 07:25 #19575 by Tom Z
OK TH shows up in the Devo 12 emulator but not the Devo 8 emulator which is the screen shot I post above.
I will have to ask one of the tech guys about this.
Devo 12 emulator
01 Feb 2014 07:41 #19576 by Tom Z
I figured it out! Only the Devo 12 Tx has a HOLD1 option.
I am going to assign TH to RUD DR1 so it will work on all the transmitters.
01 Feb 2014 11:34 #19583 by Mullson
I think it's the other way around. Its only Devo 8 that doesn't have the hold 0,1 named sw. A little question for Tom Z, have you done a ini for brushless superCP 14000kv or other?
If not I will start a new thread.
01 Feb 2014 12:50 - 01 Feb 2014 13:10 #19586 by Tom Z
The Devo 6/6S/7e/10 doesn't have the HOLD1 either, only the Devo 12 has HOLD1.
My "Walkera CP Helicopters" model works on the following helicopters brush or brushless.
Last edit: 01 Feb 2014 13:10 by Tom Z.
01 Feb 2014 16:31 #19594 by WheresWaldo
Replied by WheresWaldo on topic My first experience utilizing the advanced mixer
Copy to... will let you copy the current model configuration to another model (preferably a blank one).
01 Feb 2014 16:35 #19595 by ave1
The "copy to" function which resides on the ch order menu page.
01 Feb 2014 17:07 #19602 by Tom Z
WheresWaldo wrote: Copy to... will let you copy the current model configuration to another model (preferably a blank one).
Thanks, I will try it.
01 Feb 2014 17:08 #19603 by Tom Z
ave1 wrote: Oh ya sure, put my name so, when they crash, they come hunt me down, I see.
Smile you!
Better you than me... Lol
I just posted the models.
deviationtx.com/forum/model-configs
  • rbe2012
  • rbe2012's Avatar
01 Feb 2014 19:19 #19611 by rbe2012
ave1 wrote: The "copy to" function which resides on the ch order menu page.
This is used for copying one channel's mixer config to another channel. If you have done that, you have two channels with identical mixers (besides the output channel, of course).
Time to create page: 1.674 seconds
