Help. New LIPO Battery for Devo 12S
- Dandan123
20 Feb 2014 03:08 - 20 Feb 2014 21:35 #20628
by Dandan123
Help. New LIPO Battery for Devo 12S was created by Dandan123
Hi I need some help with a new lipo for Devo 12S. That is my first topic, so sorry for the bad english. I have bought a Devo 12S yesterday and I did't receive the original battery pack (Lipo BT3000). It is difficult to find a spare BT3000 pack. I was imagine that I could use a different pack, maybe some with more than 3,7V and more than 3000. But I don't even know where is the positive and the negative in the control plug, anyone who has a Devo12S could check on the original battery where is the positive and the negative? What is the best pack for the Devo 12S. Is possible use a 2S pack?
I have found this pack below, but I need the size specifications of the original battery to know if it will fit the control. Thanks for the help.
www.hobbyking.com/hobbyking/store/__1727..._ROAR_APPROVED_.html
Last edit: 20 Feb 2014 21:35 by Dandan123.
- dat
21 Feb 2014 04:12 - 21 Feb 2014 04:38 #20679
by dat
Replied by dat on topic Help. New LIPO Battery for Devo 12S
I like to know , Dose 2S can fit on 12S ?
If it can fit and that i will buy one for a spare !
another question is May i use rechargeable Ni-MH battery like SANYO eneloop
1.2V x 4 ,a pack in 4.8V on my Devo 12S ? Will it or won't burn 12S use a Ni-MH pack in 4.8V?
Last edit: 21 Feb 2014 04:38 by dat.
- IMback!
21 Feb 2014 07:10 - 21 Feb 2014 07:11 #20684
by IMback!
should be fine. its kinda hard to buy components rated at 4.2v everything's rated to at least 5v
Replied by IMback! on topic Help. New LIPO Battery for Devo 12S
dat wrote: another question is May i use rechargeable Ni-MH battery like SANYO eneloop
Last edit: 21 Feb 2014 07:11 by IMback!.
- ZOOCOCO
21 Feb 2014 15:21 #20697
by ZOOCOCO
Replied by ZOOCOCO on topic Help. New LIPO Battery for Devo 12S
Open the control unit and check from inside and you can see positive or negective.
I think you can buy a 2S pack and open it make 2 1S battery just to stay on the safe side.
Devo 12 is rather expensive to try and plug in higher voltage but I had plug 8.4v in my DEVO 7E no problem.
- Dandan123
21 Feb 2014 17:07 - 21 Feb 2014 19:49 #20700
by Dandan123
Replied by Dandan123 on topic Help. New LIPO Battery for Devo 12S
The link of hobby king show a battery with 1S with 5000mh. That is why I would rather use this. 2S could be a alternative, but just if anyone tried before. I don't have enough knowledge about electronics to know if I can use a 2S. Open a 2S pack are dangerous and I will need at least 2000mh to be useful. Thanks for the help. I will try to post a solution very soon. Thanks
Edit: Inferior plug is the Positive one. Now how to discover if 2S is capable?
Last edit: 21 Feb 2014 19:49 by Dandan123.
- Fishfiend
24 Feb 2014 10:08 #20827
by Fishfiend
Replied by Fishfiend on topic Help. New LIPO Battery for Devo 12S
How about just getting the original battery pack..it usually takes about 2 weeks to the uk no sure where you are based, but at least you'll be getting the real deal..
www.hobbyone.com.hk/cn/product.jsp?id=11258
- Hexperience
26 Feb 2014 17:44 #20895
by Hexperience
A 4.8v pack fully charged may be a little high. But if it does work make sure to never try to charge them with the devo12. I'm sure the charging circuit won't like it.
Replied by Hexperience on topic Help. New LIPO Battery for Devo 12S
dat wrote: I like to know , Dose 2S can fit on 12S ?
- Hexperience
26 Feb 2014 17:45 #20896
by Hexperience
- BirdBarber
- Hummingbird Assassin
03 Aug 2014 11:46 #24995
by BirdBarber
Replied by BirdBarber on topic Help. New LIPO Battery for Devo 12S
AUGUST 3rd 2014: Better late than never!
EHirobo finally has the official WK-BT3000 battery in stock, they are the only place I have ever seen them actually in stock. They are $15 plus $7 shipping to the US.
www.ehirobo.com/walkera-wk-bt3000-3-7v-3...or-devo-12s-f12.html
I have one on order.
- dat
08 Aug 2014 01:51 #25090
by dat
hi pal! my friend have done for me two of old 3s 1000mah bats become to 1s 3000mah. so now i got 3 bats for 12S.
All works fine on my devo 12s.
- BirdBarber
10 Aug 2014 07:29 #25119
by BirdBarber
August 9th 2014: my Devo 12S battery arrived already!
The WK-BT3000 battery does still exist, I got mine from eHirobo.com today.
I have been looking for 2 months, I was wondering if anyone would ever get them back in stock.
- TomPeer
Time to create page: 0.619 seconds
- Help. New LIPO Battery for Devo 12S
