Help. New LIPO Battery for Devo 12S
20 Feb 2014 03:08 - 20 Feb 2014 21:35 #20628 by Dandan123
Help. New LIPO Battery for Devo 12S was created by Dandan123
Hi I need some help with a new lipo for Devo 12S. That is my first topic, so sorry for the bad english. I have bought a Devo 12S yesterday and I did't receive the original battery pack (Lipo BT3000). It is difficult to find a spare BT3000 pack. I was imagine that I could use a different pack, maybe some with more than 3,7V and more than 3000. But I don't even know where is the positive and the negative in the control plug, anyone who has a Devo12S could check on the original battery where is the positive and the negative? What is the best pack for the Devo 12S. Is possible use a 2S pack?
I have found this pack below, but I need the size specifications of the original battery to know if it will fit the control. Thanks for the help.
www.hobbyking.com/hobbyking/store/__1727..._ROAR_APPROVED_.html
Last edit: 20 Feb 2014 21:35 by Dandan123.
21 Feb 2014 04:12 - 21 Feb 2014 04:38 #20679 by dat
Replied by dat on topic Help. New LIPO Battery for Devo 12S
I like to know , Dose 2S can fit on 12S ?
If it can fit and that i will buy one for a spare ! :cheer:
another question is May i use rechargeable Ni-MH battery like SANYO eneloop
1.2V x 4 ,a pack in 4.8V on my Devo 12S ? Will it or won't burn 12S use a Ni-MH pack in 4.8V?
Last edit: 21 Feb 2014 04:38 by dat.
21 Feb 2014 07:10 - 21 Feb 2014 07:11 #20684 by IMback!
Replied by IMback! on topic Help. New LIPO Battery for Devo 12S
dat wrote: another question is May i use rechargeable Ni-MH battery like SANYO eneloop
should be fine. its kinda hard to buy components rated at 4.2v everything's rated to at least 5v
Last edit: 21 Feb 2014 07:11 by IMback!.
21 Feb 2014 15:21 #20697 by ZOOCOCO
Replied by ZOOCOCO on topic Help. New LIPO Battery for Devo 12S
Open the control unit and check from inside and you can see positive or negective.
I think you can buy a 2S pack and open it make 2 1S battery just to stay on the safe side.
Devo 12 is rather expensive to try and plug in higher voltage but I had plug 8.4v in my DEVO 7E no problem.
21 Feb 2014 17:07 - 21 Feb 2014 19:49 #20700 by Dandan123
Replied by Dandan123 on topic Help. New LIPO Battery for Devo 12S
The link of hobby king show a battery with 1S with 5000mh. That is why I would rather use this. 2S could be a alternative, but just if anyone tried before. I don't have enough knowledge about electronics to know if I can use a 2S. Open a 2S pack are dangerous and I will need at least 2000mh to be useful. Thanks for the help. I will try to post a solution very soon. Thanks
Edit: Inferior plug is the Positive one. Now how to discover if 2S is capable?
Last edit: 21 Feb 2014 19:49 by Dandan123.
24 Feb 2014 10:08 #20827 by Fishfiend
Replied by Fishfiend on topic Help. New LIPO Battery for Devo 12S
How about just getting the original battery pack..it usually takes about 2 weeks to the uk no sure where you are based, but at least you'll be getting the real deal..
www.hobbyone.com.hk/cn/product.jsp?id=11258
26 Feb 2014 17:44 #20895 by Hexperience
Replied by Hexperience on topic Help. New LIPO Battery for Devo 12S
dat wrote: I like to know , Dose 2S can fit on 12S ?
A 4.8v pack fully charged may be a little high. But if it does work make sure to never try to charge them with the devo12. I'm sure the charging circuit won't like it. :)
26 Feb 2014 17:45 #20896 by Hexperience
  • BirdBarber
  • BirdBarber's Avatar
  • Hummingbird Assassin
03 Aug 2014 11:46 #24995 by BirdBarber
Replied by BirdBarber on topic Help. New LIPO Battery for Devo 12S
AUGUST 3rd 2014: Better late than never!
EHirobo finally has the official WK-BT3000 battery in stock, they are the only place I have ever seen them actually in stock. They are $15 plus $7 shipping to the US.
www.ehirobo.com/walkera-wk-bt3000-3-7v-3...or-devo-12s-f12.html
I have one on order.
08 Aug 2014 01:51 #25090 by dat
hi pal! my friend have done for me two of old 3s 1000mah bats become to 1s 3000mah. so now i got 3 bats for 12S. :lol:
All works fine on my devo 12s.
  • BirdBarber
10 Aug 2014 07:29 #25119 by BirdBarber
August 9th 2014: my Devo 12S battery arrived already!
The WK-BT3000 battery does still exist, I got mine from eHirobo.com today.
I have been looking for 2 months, I was wondering if anyone would ever get them back in stock.
Time to create page: 0.314 seconds
