wltoys wl 931 as 350
13 Jan 2015 13:43 #27649 by Pavel123
wltoys wl 931 as 350 was created by Pavel123
Dear all,
I have one question - please, is it possible to use Devo 6 transmitter, in case that I will use Deviation firmware for Wltoys WL 931 as350 helicopter?
I saw the table with Supported models, there are many models by WL Toys, but WL 931 unfortunately not.
13 Jan 2015 14:56 #27652 by TomPeer
Replied by TomPeer on topic wltoys wl 931 as 350
Hello
Yes you can fly the V931 very well with deviation. Use the same protocol as the v977.
13 Jan 2015 15:05 #27653 by Pavel123
Replied by Pavel123 on topic wltoys wl 931 as 350
Thank you very much for your reply. This is very good message for me :)
13 Jan 2015 16:02 #27655 by Pavel123
Sorry, I have once more question:
The receiver (control board) for V977 wltoys helicopter should have 2 modes - 3-axis for acrobatics and 6-axis for beginners. These modes should be change during flight by transmitter.
Please, is it possible to use this function using Devo6 transmitter with Deviation FW?
Thank you
14 Jan 2015 08:08 - 14 Jan 2015 08:08 #27672 by Pavel123
Please, I have the additional question - is it necessary to add any additional Tx modul to the transmitter?
Last edit: 14 Jan 2015 08:08 by Pavel123.
14 Jan 2015 14:15 #27675 by aMax
Replied by aMax on topic wltoys wl 931 as 350
If you had looked at the main menu of Deviationrx.com, you would have found something like this.
docs.google.com/spreadsheet/ccc?key=0Any...kE&usp=sharing#gid=0
......V931 = V977
14 Jan 2015 19:23 #27683 by TomPeer
you can change from 3-axis to 6-axis (and back) with a flip of a switch.
and you have to install an extra module: nrf24L01.
15 Jan 2015 14:08 #27706 by Pavel123
thank you very much for your reply :) now it is clear for me :)
15 Jan 2015 21:27 #27720 by mwm
Replied by mwm on topic wltoys wl 931 as 350
aMax wrote: If you had looked at the main menu of Deviationrx.com, you would have found something like this.
......V931 = V977
Has this been tested? WLToys tends to muck with their protocol stuff sort of randomly, so while you may be able to bind and fly one aircraft with the controller or protocol selection that works with another, the extra features (like switching modes) may not work. These two have different Rx boards (HT-WL06R vs. XHT-WF-06R), so this may be the case here. Maybe someone has verified that all the functions of the 931 can be accessed from the 977 RTF Tx?
15 Jan 2015 21:57 #27725 by aMax
At least the transmitter is the same. The parameter on the rx boards for 2 or 3 blades may vary.
I do not know if these transmitters have special models to select.
www.banggood.com/WLtoys-V966-V977-6CH-He...mitter-p-922666.html
15 Jan 2015 22:01 #27726 by mwm
If they use the same Tx, then all the functions of that Tx that work with one using deviationTx should work with the other.
16 Jan 2015 08:07 #27736 by Pavel123
.....you can change from 3-axis to 6-axis (and back) with a flip of a switch.
I found the next informations about wl 977 in this forum:
www.deviationtx.com/forum/protocol-devel...otocol-v977?start=20
and there is written, that the BK2423 module is used in the wl transmitter for wl 977 (if I understand correctly).
It means, that both of modules are interchangeable?
16 Jan 2015 16:35 - 16 Jan 2015 17:10 #27741 by TomPeer
I have the v977 and the v931. They both fly with the same transmitter. In deviation i use the same ini for both heli's. They fly great. specialy the v931.
Last edit: 16 Jan 2015 17:10 by TomPeer.
19 Jan 2015 09:44 #27844 by Pavel123
Thanks, the v931 is very beautiful heli and I would like to have it.
Please, my question is what additional 2,4GHz module must be added to Devo 6 transmitter. In the table RC Model Database is NRF24L01 module, but in the another topic in this forum is the BK2423 module.
Thank you
19 Jan 2015 14:48 #27845 by hexfet
Replied by hexfet on topic wltoys wl 931 as 350
Those two devices are compatible. Either will work.
19 Jan 2015 16:38 #27849 by Pavel123
Many thanks for every answer! :)
Please, I have once more questions. Sorry, hope, that they are the last questions :)
In case, that I will have my Devo 6 upgraded to Deviation and I will have additional module for v931 (or any other), it will be simply possible to use both of protocols? - original Walkera Devo (e.g. for V120D02s heli) and v931 heli?
Is it possible to switch between both protocols without edit tx.ini file?
Is it possible to switch between both modules using some switch (e.g. external) for switching power supply between modules and to have active only one module?
Thank you
19 Jan 2015 17:08 #27850 by TomPeer
You set the protocol when you setup your model the first time. After that; if you choose your model on your transmitter, the needed protocol will automatic be choosen, you don't have to do anything else.
After you installed the new modules, you have to edit the tx.ini (or hardware.ini when you use the nightly builts). This is a one time thing, you do not need to change anything again, unless you install another module.
The transmitter change to the right module for you. You do not need to switch yourself.
In the transmitter, you choose witch heli, quad or plane you want to fly. The transmitter then automaticly choose the needed module.
19 Jan 2015 17:38 #27853 by Pavel123
Thank you very much for your detailed answer! Now it is clear for me B)
24 Jan 2015 08:13 #27959 by Gerhard_H
Replied by Gerhard_H on topic wltoys wl 931 as 350
Hi !
I also had purchased a WLToys AS350 and want to use my DEVO 7E radio.
Therefore I purchased a NRF24L01 module and made soldering following the instructions on Daryoon's Devo 7e - RC Groups.htm., the link is to find somewhere here in the forum.
But it doesn't bind.
My firmware is deviation-devo7e-v4.0.1-92e1705.dfu
This is my hardware.ini:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A13
has_pa-nrf24l01 = 1
enable-multimod = A13
I don't know whether the last line is correct: enable ? Disable ?
I also found out that the last line of the tx.ini ist filled with NUL, which isn't with the hardware.ini. Does this matter ?
The heli's radio is OK, it binds instantly with the original radio.
Also the DEVO 7E radio, other protocols like DSMX are working.
Now I don't know how to proceed.
Any help is appreciated.
THX in advance
Gerhard
24 Jan 2015 09:29 - 24 Jan 2015 09:30 #27960 by Gerhard_H
Hi again !
Gerhard_H wrote: . . . following the instructions on Daryoon's Devo 7e - RC Groups.htm., the link is to find somewhere here in the forum. . . .
For sure :
This is the link
www.hacksmods.com/2013/05/nrf24l01-devo7e-pinout/
I had followed.
Gerhard
Last edit: 24 Jan 2015 09:30 by Gerhard_H.
Time to create page: 0.982 seconds
