- devention-devo10-v4.0.1 USBHID not working
- seurat
08 Feb 2015 19:09 #28463
by seurat
devention-devo10-v4.0.1 USBHID not working was created by seurat
Hi *,
I just flashed my DEVO-10 with deviation-devo10-v4.0.1 and wanted to use it with HELI-X 5.0. I started with the Phoenix.ini posted by MWM ( deviationtx.com/forum/model-configs/2013...-10-on-phoenix#12412 ), chose USBHID protocol in the model settings and connected the DEVO to my PC (running Ubuntu 14.01) via the usb cable.
No joystick devices show up in the system. Tried the same with Windows 7 Pro running on VMWare Player without any success.
I have attached my model1.ini file.
What am I doing wrong?
Rgds, Seurat
Rgds, Seurat
08 Feb 2015 19:36 #28468
Replied by mwm on topic devention-devo10-v4.0.1 USBHID not working
This sounds like a system problem, not a deviationTx problem. You need to troubleshoot your USB drivers. Do you get anything at all on ubuntu?
- seurat
08 Feb 2015 22:15 - 10 Feb 2015 14:12 #28478
by seurat
Replied by seurat on topic devention-devo10-v4.0.1 USBHID not working
Hi mwm,
I have a PPM2USB dongle from ModellKraft that works flawlessly with deviation PPM & Heli-X! That is why I believe there must be some problem with my deviation Tx USBHID setup.
What I have done:
# lsusb -v -s 001:017
Bus 001 Device 017: ID 0483:5710 STMicroelectronics Joystick in FS Mode
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0483 STMicroelectronics
idProduct 0x5710 Joystick in FS Mode
bcdDevice 2.00
iManufacturer 1 DeviationTx
iProduct 2 Deviation GamePad
iSerial 3 1.0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 1 Boot Interface Subclass
bInterfaceProtocol 2 Mouse
iInterface 0
HID Device Descriptor:
bLength 9
bDescriptorType 33
bcdHID 1.00
bCountryCode 0 Not supported
bNumDescriptors 1
bDescriptorType 34 Report
wDescriptorLength 49
Report Descriptors:
** UNAVAILABLE **
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 32
Device Status: 0x0003
Self Powered
Remote Wakeup Enabled
OK, the OS sees a Joystick in FS mode.
I notice it implements only channels, no buttons. Why is this?
I guess I was missing the Re-Init step!
Problem solved!
Thnx.
What I have done:
- Set model protocol to USBHID
- Press ENTER on Re-Init 2 times
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
bcdDevice 2.00
iSerial 3 1.0
bLength 9
bDescriptorType 2
wTotalLength 34
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 100mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 9
bDescriptorType 33
bcdHID 1.00
bNumDescriptors 1
Report Descriptors:
** UNAVAILABLE **
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 32
Self Powered
Problem solved!
Thnx.
Last edit: 10 Feb 2015 14:12 by seurat.
Time to create page: 0.093 seconds
