Range Devo 7E and Devo 10
- saidem
09 May 2015 16:10 #32303
by saidem
Range Devo 7E and Devo 10 was created by saidem
I would like to fly a glider with Devo 7E whose diode change was made. Will it have the same range as a 10 Devo?
- saidem
13 May 2015 16:37 #32502
by saidem
Replied by saidem on topic Range Devo 7E and Devo 10
I'm sorry, I still have no answer to this topic. Anyone know it enough to answer me.
Thank you.
Thank you.
13 May 2015 16:51 #32505
Replied by vlad_vy on topic Range Devo 7E and Devo 10
With diode mod Devo 7e has the same range as Devo 10.
- saidem
13 May 2015 16:56 #32508
by saidem
In fact I was wondering because Devo 10 has a much larger antenna than 7E Devo?
- aMax
13 May 2015 17:05 #32509
by aMax
Replied by aMax on topic Range Devo 7E and Devo 10
The antenna is not bad at all, only can not be bent and turned to a more suitable direction for emission.
I always point to the ground or hold the TX sideways at long range.
- saidem
13 May 2015 17:18 #32511
by saidem
In fact I took the antenna of its housing and I put it horizontally inside the TX.
- aMax
13 May 2015 17:34 - 13 May 2015 18:13 #32513
by aMax
Then you are on the right track....
What about modding the 7e with a socket and a RG178 cable? Got my set from a chinese trader for 3$.
e.g............ www.hacksmods.com/category/devo-2/
Last edit: 13 May 2015 18:13 by aMax. Reason: my glasses....I am getting old
- saidem
13 May 2015 18:29 #32517
by saidem
I have the original the module (CYRF6936), its antenna is directly soldered on the module and at the end of the antenna there is a BODA. So I think it is not easy to replace it? Anyway if the range is the same, it's not worth doing it.
Time to create page: 0.092 seconds
- Range Devo 7E and Devo 10
