White devo 10 and NRF24l01
17 May 2015 15:33 #32691 by harmony96
White devo 10 and NRF24l01 was created by harmony96
Hi.
I have a problem to install NRF24L01 module to my white devo 10.
I have two walkera radios.
One is devo8s, and the other is devo 10.
In devo8s, I had installed A7105 and CC2500 modules.
In devo10 (White), I had installed A7105 and NRF24l01 modules.
Devo8s works fine.
I can successfully bind and fly helicopters from other vendors.
In a case of devo10 (white), I can use A7105 module. I can bind v911 and other RCs from wltoys.
However, I could not bind hcp80 and v977.
Of course, I carefully checked the wires many times.
Also, because I have experiences to install other three modules, I believe that the probability for bad wiring is low.
So, I first doubt my NRF24l01 module that I bought from aliexpress.
After that, I placed an order for the new NRF24l01 module.
Today, I have installed it....
But, still not working.
I have a radio adapter for hisky (HT8).
When I use the HT8, the HCP80 and v977 work.
So the helicopters have no problem.
What I tried is to change the enable signal.
If one of CE (chip enable) in my devo10 white is not normal, only one of modules will work.
So, I tried to change CE between A7105 and NRF24l01.
The A7105 works for any CEs.
What should I do?
Any suggestions and advice are welcome.
Thank you.
17 May 2015 15:44 #32692 by SilbernerSurfer
Replied by SilbernerSurfer on topic White devo 10 and NRF24l01
harmony96 wrote: Hi.
Hello harmony96,
I want to install the nrf to a white Devo 10 too.
Is there a description in the internet how to do this?
Thanks in advance!
Uwe
17 May 2015 17:09 #32695 by aMax
Replied by aMax on topic White devo 10 and NRF24l01
@harmony96
Which firmware version is on the tx? Did you bind CE to Vcc?
17 May 2015 17:20 - 17 May 2015 17:22 #32697 by Deal57
Replied by Deal57 on topic White devo 10 and NRF24l01
harmony96 wrote: ...
What should I do?
Thank you.
aMax beat me to it! I think that's a good question.
Can you post a photo of your wiring or maybe a schematic? In my schematic, the CE for the NRF24L01 module is tied to Vcc and always high. The CSN line is connected to your TMS or TCK on the TX board. Is it possible you've reversed the purpose of those two lines?
Solder Point on NRF24L01
Last edit: 17 May 2015 17:22 by Deal57.
19 May 2015 10:24 - 19 May 2015 10:24 #32767 by harmony96
Replied by harmony96 on topic White devo 10 and NRF24l01
aMax wrote: @harmony96
Wow!!!!
I misunderstood the signals of CE and CSN.
I thought that I carefully checked all signals, but I was wrong.
Now it is working..
My devo 10 can bind my birds on FW 4.0.1.
However, after upgrading it to nightly build (2015-05-15), the protocols related with additional modules are disabled.
In front of protocols, there is asterisk.
What I did was....
1) download nightly build for devo 10
2) delete all the files in devo drive.
3) Edit hardware.ini in hard drive.
4) Copy the new files to devo.
5) double-check hardware.ini in devo10.
The followings is my hardware.ini
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
; enable-multimod = A13
Thank you!
Last edit: 19 May 2015 10:24 by harmony96.
19 May 2015 11:05 #32768 by mwm
Replied by mwm on topic White devo 10 and NRF24l01
Note that the hardware connections for anything after 4.0.1 are sitters different than they are for 4.0.1. Did you change that as well?
20 May 2015 04:35 #32786 by harmony96
mwm wrote: Note that the hardware connections for anything after 4.0.1 are sitters different than they are for 4.0.1. Did you change that as well?
Thank you.
How can I change the hardware connections? Do you mean that I should change the connections of additional modules?
20 May 2015 04:45 #32787 by harmony96
harmony96 wrote: How can I change the hardware connections? Do you mean that I should change the connections of additional modules?
I found an answer.
I need DFU upgrade for the nightly builds.
Time to create page: 0.136 seconds
