Devo 7E
18 May 2015 01:23 #32717 by skibill
Devo 7E was created by skibill
After update , it wiped all data out .Unable to install data now . Can anyone help
18 May 2015 02:04 #32718 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 7E
I'm sorry but we need some more information about what the issue is.
If you cannot get back to the programming page, you should pull the battery out, wait 10 seconds, make sure the Tx is off, and then plug the battery back in.
If your problem is elsewhere, you should post more details about the issue.
11 Jun 2015 18:03 #33859 by skibill
Replied by skibill on topic Devo 7E
This is what I have on the devo 7e now and that is all,it says in the defuse that 4.0.1 installed correctly.All I get is black spots.
see attachments
thank you,
Bill
11 Jun 2015 18:20 #33862 by skibill
This is all I get after update, with 4.0.1 firmware. I tried pulling the battery out, then tried update again. Th dfuse upgrade tool says that it correctly loaded. I get nothing but black marks as you can see in attachments.
thank you,
Bill
(it said failed to upload file, the uploaded file was only partially uploaded.
so I will try again) sorry
11 Jun 2015 18:43 - 11 Jun 2015 18:53 #33865 by skibill
I had the wrong format for pictures,sorry
if you can not load pictures than why do they have a place for attachments?????????????????
I tried three times and the picture are jpeg
Last edit: 11 Jun 2015 18:53 by skibill. Reason: NO PICTURES
12 Jun 2015 00:03 #33886 by mwm
Replied by mwm on topic Devo 7E
You can upload pictures, but it's really picky about them. There's a size limit, and it has to have an extension that the thing likes. I.e. - I can't upload ".text" files without first renaming them to ".txt". Yeah, it's silly and takes me back to the 80s.
Check the size on your image, and make sure the extension is .jpg and not .jpeg or something else.
12 Jun 2015 00:38 #33893 by PhracturedBlue
lots of sites have restrictions on what you can upload. Unfortunately Kunena doesn't provide any feedback as to what you did wrong, so it is infuriating to figure out where your attachments go. I wonder if there is a plugin for that.
12 Jun 2015 04:21 #33903 by FDR
Replied by FDR on topic Devo 7E
Actually Kunena gives a message, it is just shown at the top of the page, which usually stays unrealized...
BTW it shows the allowed extensions in tooltip over the Add File button too, at least for me on Chrome it does.
The picture limit is 1MB.
Time to create page: 0.197 seconds
