Devo 7e Deviation 4.0.1 and Syma X-11c
25 Jul 2015 20:41 - 25 Jul 2015 20:42 #35976 by zorkx
Hi.
I've modded my Devo 7e with the nrf24l01 module and soldering went well.
After that i flashed the deviaton 4.0.1 and copied the files to the Devo 7e flash drive.
The Devo 7e boots normally, deviation 4.01 logo and no reboots or error messages.
When go to model setup, and try to load a file nothing shows up, it only show mode 1 and none while i copied al the protocols to the protocol directory.
Has this something to do with my nrf24l01 module or am i doing something wrong.
Tried the stock deviation firmware, nightly builds, combinations of firmwares but nothing seems to work.
Can someone please help what to do ?
Last edit: 25 Jul 2015 20:42 by zorkx.
25 Jul 2015 20:52 - 25 Jul 2015 20:53 #35977 by greenfly
Replied by greenfly on topic Devo 7e Deviation 4.0.1 and Syma X-11c
Did you enable the module in the hardware.ini file (on the root of the Devo's filesystem) ?
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
You have to remove the semicolons in front of the lines.
Last edit: 25 Jul 2015 20:53 by greenfly.
25 Jul 2015 21:16 - 25 Jul 2015 21:18 #35978 by TomPeer
Replied by TomPeer on topic Devo 7e Deviation 4.0.1 and Syma X-11c
After getting the firmware in to your devo, the model list is still empty. You have to copy the model.ini files later. Or make them your self.
If you want to copy model.ini files you can find them here on the forum, download them to your computer and then copy them to your transmitter in the models directory, by replacing the existing model1.ini, model2.ini , etc.... Do not give them another name.
If you want to fly the syma quad, then you have to load the latest nightly firmware.
Last edit: 25 Jul 2015 21:18 by TomPeer.
25 Jul 2015 21:29 - 25 Jul 2015 22:27 #35979 by zorkx
Replied by zorkx on topic Devo 7e Deviation 4.0.1 and Syma X-11c
I did.
Watched frequent flyers RC video tutorial on YouTube.
He only mentioned to remove the ; and change the other one to a13.
Last edit: 25 Jul 2015 22:27 by zorkx.
25 Jul 2015 21:36 - 25 Jul 2015 21:37 #35981 by zorkx
Oké.
So i must download a custom ini x11c from the rcgroups forum, copy it tot my devo 7e and rename it to mode 1 ?
Last edit: 25 Jul 2015 21:37 by zorkx.
25 Jul 2015 21:59 - 25 Jul 2015 22:24 #35985 by zorkx
TomPeer wrote: After getting the firmware in to your devo, the model list is still empty. You have to copy the model.ini files later. Or make them your self.
First of all sorry i forgot to quote you guys.
Do you mean the latest nightly on the deviation website ? June 2015
I also mentioned the 4.0.1 deviation firmware doesn't contain the symax protocol, and also saw when someone posts a list of custom protocols they include a new firmware.
Do i have tot upgrade to the included firmware tot use that protocols ?
Last edit: 25 Jul 2015 22:24 by zorkx.
25 Jul 2015 22:36 #35993 by TomPeer
yes, i do mean the 19-6-2015 nightly build.
this built has the syma protocol.
you can find more info here: www.deviationtx.com/forum/protocol-devel...8-syma-x5c-1-x11-x12
26 Jul 2015 10:51 - 26 Jul 2015 10:53 #36024 by zorkx
TomPeer wrote: yes, i do mean the 19-6-2015 nightly build.
Oké, it works.
Do i need to calibrate the quad manualy because its twisting and turning now?
Last edit: 26 Jul 2015 10:53 by zorkx.
26 Jul 2015 11:00 #36025 by TomPeer
you have to calibrate the devo.
i do not know about the quad, i don't own one.
27 Jul 2015 19:20 #36181 by zorkx
TomPeer wrote: you have to calibrate the devo.
Is there any manual how to calibrate the Devo 7e ?
27 Jul 2015 19:39 - 27 Jul 2015 19:39 #36183 by TomPeer
Power on the tx.
Push the ENT button,
goto Transmitter menu,
goto Transmitter config,
there you see the button Calibrate,
Push Calibrate and follow the instructions on the screen.
Good luck and have fun flying
Last edit: 27 Jul 2015 19:39 by TomPeer.
27 Jul 2015 20:16 #36186 by zorkx
TomPeer wrote: Power on the tx.
thanks :D
Time to create page: 0.176 seconds
