- CC2500 mod-display blinking/unstable Tx voltgage
- lovecveverek
03 Sep 2015 21:50 - 03 Sep 2015 23:16 #37413
by lovecveverek
CC2500 mod-display blinking/unstable Tx voltgage was created by lovecveverek
Hi all,
I ve been happily using devo 7e + NRF24L01 and i recently installed CC2500, I connected CC2500 through pins on NRF24L01 + separate CNS. It all works, it binds to d4r-ii via FrSky protocol. However, when cc2500 employed, I can see the display fluctuating/blinking and the Tx voltage is very unstable. When I switch protocols that goes through NRF24L01 the issues disappear. See video below. The display blinking can't be seen in the video, I guess it s because the refresh rate of the camera. For the module connection see the picture.
Anyone has any idea what s going on?
EDIT: alright, friend of mine suggested not to use this kind of pseudo-serial layout of the modules but paralel one. Gonna resolder.
Last edit: 03 Sep 2015 23:16 by lovecveverek. Reason: update
- aMax
03 Sep 2015 23:35 - 03 Sep 2015 23:47 #37415
by aMax
Replied by aMax on topic CC2500 mod-display blinking/unstable Tx voltgage
The voltage fluctuation is normal, > 2way transmission >telemetry.
The higher you set the transmitter output power, the more will it be.
Even my Futaba FC18V3 plus has this issue with the Frsky DFT module.
Last edit: 03 Sep 2015 23:47 by aMax. Reason: typo
04 Sep 2015 03:38 #37420
Replied by mwm on topic CC2500 mod-display blinking/unstable Tx voltgage
I've got two different Tx's set up with two modules in serial like you describe. Both work fine.
Time to create page: 0.300 seconds
