devo 7e + nrf24l01 bind wltoys a979 problem.
24 Sep 2015 13:54 #38029 by saydals
I can bind a979 with devo 7e ( nightly build)
but... a979 can't run backward....
someone help me...
04 Oct 2015 12:51 - 04 Oct 2015 12:53 #38415 by djzinc
same problem a friend of mine have (had).
try this:
set the stick you use for FWD/REV with 9 point curve: -100, -65, -30, 0, 1, 0, 30, 65, 100.
good luck!
Last edit: 04 Oct 2015 12:53 by djzinc.
31 Jan 2016 00:15 #42441 by xuyuan
Have you solved the problem? Here is exactly the same.
9 point curve doesn't help
31 Jan 2016 17:24 #42467 by djzinc
I'm sorry to hear that.
No, I didn't look for other solution, because that one is working for me too.
14 Apr 2016 14:45 #46494 by Twilight_Sun
Replied by Twilight_Sun on topic devo 7e + nrf24l01 bind wltoys a979 problem.
I've also used curve like that. It run backward, but it need 0.5-1s in neutral position after forward and then it works.
16 Apr 2016 08:06 #46605 by djzinc
Yes, the time in neutral is compulsory. even with the stock transmitter you have to make that pause in "0" to be able to run in backward.
Time to create page: 0.206 seconds
