- devo 7e + nrf24l01 bind wltoys a979 problem.
- saydals
24 Sep 2015 13:54 #38029
by saydals
devo 7e + nrf24l01 bind wltoys a979 problem. was created by saydals
I can bind a979 with devo 7e ( nightly build)
but... a979 can't run backward....
someone help me...
someone help me...
- djzinc
04 Oct 2015 12:51 - 04 Oct 2015 12:53 #38415
by djzinc
Replied by djzinc on topic devo 7e + nrf24l01 bind wltoys a979 problem.
same problem a friend of mine have (had).
try this:
set the stick you use for FWD/REV with 9 point curve: -100, -65, -30, 0, 1, 0, 30, 65, 100.
good luck!
try this:
good luck!
Last edit: 04 Oct 2015 12:53 by djzinc.
- xuyuan
31 Jan 2016 00:15 #42441
by xuyuan
Replied by xuyuan on topic devo 7e + nrf24l01 bind wltoys a979 problem.
Have you solved the problem? Here is exactly the same.
9 point curve doesn't help
- djzinc
31 Jan 2016 17:24 #42467
by djzinc
I'm sorry to hear that.
No, I didn't look for other solution, because that one is working for me too.
- Twilight_Sun
14 Apr 2016 14:45 #46494
by Twilight_Sun
Replied by Twilight_Sun on topic devo 7e + nrf24l01 bind wltoys a979 problem.
I've also used curve like that. It run backward, but it need 0.5-1s in neutral position after forward and then it works.
- djzinc
16 Apr 2016 08:06 #46605
by djzinc
Yes, the time in neutral is compulsory. even with the stock transmitter you have to make that pause in "0" to be able to run in backward.
Time to create page: 0.199 seconds
