- Problem with stock DEVO 7E and Nano CP S
- vmsda
07 Jun 2016 16:56 - 07 Jun 2016 17:03 #50111
by vmsda
Problem with stock DEVO 7E and Nano CP S was created by vmsda
I am working on a 7E with no extra switches installed, and aim to emulate the SAFE technology. So, first I defined the button EXT as a THR HOLD toggle, tested, everything fine. Stock HOLD 0/1 freed as intended.
Then I coded Channels 1 and 6 to mirror the CP S three flight modes. But when I tested, found out that the rotor head is not spinning! Channel monitor tells me that all stick movements behave normally (I use stick mode 3), but the THR stick does not output anything on channel 1, just on ch 6.
Being a novice, and a stubborn one at that, I must be making some childish mistake (s). My test ini file attached along with some comments. Help highly appreciated.
Last edit: 07 Jun 2016 17:03 by vmsda. Reason: Attaching a file
- HappyHarry
07 Jun 2016 19:25 #50122
by HappyHarry
Replied by HappyHarry on topic Problem with stock DEVO 7E and Nano CP S
try this bud
name=nano
mixermode=Advanced
[radio]
protocol=DSMX
num_channels=7
tx_power=150mW
[protocol_opts]
Telemetry=Off
[channel1]
safetysw=Virt1
safetyval=-125
template=complex
[mixer]
src=THR
dest=Ch1
switch=HOLD1
curvetype=3point
points=100,100,100
smooth=1
[mixer]
src=THR
dest=Ch1
switch=FMODE1
scalar=80
curvetype=3point
points=100,100,100
smooth=1
[mixer]
src=THR
dest=Ch1
switch=FMODE0
curvetype=5point
points=-100,-25,40,60,80
smooth=1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
curvetype=expo
points=25,25
[channel3]
template=simple
[mixer]
src=ELE
dest=Ch3
curvetype=expo
points=25,25
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=25,25
[channel5]
template=complex
[mixer]
src=AIL
dest=Ch5
switch=FMODE0
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Ch5
switch=FMODE1
scalar=0
usetrim=0
curvetype=fixed
[mixer]
src=AIL
dest=Ch5
switch=HOLD1
scalar=-100
usetrim=0
curvetype=fixed
[channel6]
template=complex
[mixer]
src=THR
dest=Ch6
switch=HOLD1
usetrim=0
curvetype=5point
points=-40,-20,0,20,40
smooth=1
[mixer]
src=THR
dest=Ch6
switch=FMODE1
usetrim=0
curvetype=5point
points=-60,-30,0,30,60
smooth=1
[mixer]
src=THR
dest=Ch6
switch=FMODE0
usetrim=0
curvetype=5point
smooth=1
[virtchan1]
name=THOLD
template=complex
[mixer]
src=Virt1
dest=Virt1
scalar=0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=Virt1
pos=Exit
neg=TRIMRV-
step=192
value=100,0,0
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch1
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor- vmsda
07 Jun 2016 21:17 - 07 Jun 2016 21:17 #50138
by vmsda
Replied by vmsda on topic Problem with stock DEVO 7E and Nano CP S
Point taken, HappyHarry, thank you.
Now, for the next step in the learning curve. Oh boy, how this interminable staircase wears one down ...
Last edit: 07 Jun 2016 21:17 by vmsda.
- HappyHarry
07 Jun 2016 21:33 #50143
by HappyHarry
yeah there is a lot to learn in the beginning, but don't give up, as when you finally get to the point of understanding it feels all the better an accomplishment
Time to create page: 0.901 seconds
