running out of virtual channels
26 Jul 2016 16:54 - 26 Jul 2016 17:10 #52179 by jjk836
running out of virtual channels was created by jjk836
I'm running out of virtual channels with my H101 config. Is it possible to increase the number to 12? (It might be as NUM_VIRT_CHANNELS can be changed in the source but so far I don't have my own build environment - could be a reason to set one up ;-).
That's why I need them:
button for flipping 2 channels
button for inverting 2 channels
button for return to home 2 channels
button for setting new heading 1 channel
button for resetting the gyros 1 channel
one helper holds the absolute maximum of the cyclics
one helper holds the absolute throttle value (for safety and display)
one helper flip or invert mode active
emergency throttle hold on gear 1 channel
My ini file repository bitbucket.org/jjk836/devo10
Last edit: 26 Jul 2016 17:10 by jjk836.
26 Jul 2016 18:31 #52181 by HappyHarry
Replied by HappyHarry on topic running out of virtual channels
you need to be more economic in your prigramming, flip, invert and rth can all be done with 1 ch each. how about you post your ini
26 Jul 2016 20:49 #52189 by jjk836
Replied by jjk836 on topic running out of virtual channels
That's good news. any help is appreciated. Another problem I can't solve is, that virtchan10 doesn't show the maximum of virt5 and virt7. I also tried Ch5 and Ch6 as input, it neither works.
CH1     AIL     Dual Rate on AIL DR
CH2     ELE     Dual Rate on ELE DR
CH3     THR     throttle curve on MIX 0=1-1, 1=heavy model, 2=light model
CH4     RUD     Dual Rate on RUD DR
CH5     TRIM_L+ invert (virt7, virt8, trim7) push button and move cyclic to direction
CH6     TRIM_R+ flip (virt5, virt6, trim6) push button and move cyclic to direction
CH9     FMODE   Flightmode (0=head mode, 1=headless mode)
CH10    FMODE2  Return to home (not enough virtchans for auto off in the moment)
        TRIM_R- Set new heading (only if THR=0, virt3)
        TRIM_L- Gyro callibration (only if THR=0, virt9)
        GEAR    Emergency throttle hold (virt4)
virt1   abscyclic
virt2   absthr
virt10  flip or invert mode active
26 Jul 2016 21:09 #52191 by HappyHarry
which transmitter is this for, and is it for the stock h101?
26 Jul 2016 21:41 #52193 by jjk836
devo10 and yes, for the stock h101
27 Jul 2016 05:09 #52201 by mwm
Replied by mwm on topic running out of virtual channels
You can also use any output channel that's not used by the quad as a virtual channel. Normally, I'd suggest using the higher unused channels and then setting the number of channels to control the ones you want transmitted, but that doesn't work with the h101. You need the higher numbered channels, and they are bit-bash channels which are always used even if they are above the number of channels the model transmits, though we've discussed fixing that.
Time to create page: 0.230 seconds
