K120 Config File
- richardclli
26 Jun 2017 04:07 #63143
by richardclli
K120 Config File was created by richardclli
I have installed a 4-in-1 module in Devo 12S, but cannot bind to the heli, could anybody share a workable config file for me to have a try? Not sure what the problem is. Thanks.
- Deal57
27 Jun 2017 01:08 #63162
by Deal57
Replied by Deal57 on topic K120 Config File
Here
is the thread with all the details and a model ini that should work with your 12S. The toggles may need to be adjusted. I've used this on my Devo 6s without any issues... well, except for my poor attempts at 3d, that is
I posted an icon for the XK120 back then sometime, too. Search for K120 and you'll get a lot of stuff.
Happy Flying!
Happy Flying!
- Deal57
27 Jun 2017 01:34 #63163
by Deal57
Well, it worked great with my 6s, so I tried to bind with my 12e and it took me some time. The bind button is on the control board (you cant miss it), press and hold til the red light is off. My 12e with the 4-in-1 board worked once I adjusted the coarse freq to -50. I still need to figure out the best center for that but it did the re-init and all the controls respond. But of course now my 6s isn't bound.
Anyway, so there is a bit of luck involved to finding the right freq adjustment. I just wanted to be sure the 4-in-1 was working right.
- richardclli
27 Jun 2017 13:48 #63170
by richardclli
Replied by richardclli on topic K120 Config File
Thank you for your reply, so you have the experience to bind K120, please comment if my procedures is correct or not:
1. Setup Fixed ID to 123456 (not sure if it must be 123456)
2. Setup course frequency (-50? I found 25 in some threads, seems need to try out)
3. Switch off transmitter
4. Insert battery to K120
5. Press bind button until red lights off
6. Switch on transmitter
- Deal57
27 Jun 2017 15:05 #63171
by Deal57
Almost there...
First, the "123456" fixed ID is a placeholder, and in general should be changed.
Second, yes, adjusting the frequency is specific to your transmitter chip (the CC2500 on the 4-in-1), and the adjustment may be completely different or even unnecessary. It took me few tries to find the right setting.
Other than that it's good to go.
- richardclli
15 Jul 2017 10:29 #63460
by richardclli
I cannot make it bind after trying the course freq from -70 to 70 with a 10 step. What am I missing? I spot that you mentioned the best center, how it will affect binding? About how long will it take to bind once I switch on the transmitter?
Deal57 wrote: Well, it worked great with my 6s, so I tried to bind with my 12e and it took me some time. The bind button is on the control board (you cant miss it), press and hold til the red light is off. My 12e with the 4-in-1 board worked once I adjusted the coarse freq to -50. I still need to figure out the best center for that but it did the re-init and all the controls respond. But of course now my 6s isn't bound.
- Deal57
15 Jul 2017 16:55 #63466
by Deal57
There is an interesting, if long, discussion about freq changes
in this thread.
I just rebound my 6s -- it was previously bound to my 12E. I left the fixed ID (set to some other than 123456) and checked the fine was at 100. Powered on the K120, then hold button until red light is off. I used the GUI on the 6S to adjust the fine from 100 back toward 0 and at about 20 the blue light came on! I ended up using 0 on both fine and coarse. One thing... I had the transmitter about 6" from the heli using 30mw power setting during this operation... when I tried to bind the 12E again, I had to get close and set the 30mw power. It seems to fly fine on 10mw (in my garage), but apparently binding is more sensitive.
Hope this is helpful.
- richardclli
16 Jul 2017 01:40 #63477
by richardclli
So I found from your description that you did not switch off the transmitter and tune the freq settings until the blue light appears, am I right? And it seems the transmitter power should set to lower power as well, right?
- Deal57
16 Jul 2017 03:10 #63478
by Deal57
I didn't turn off the transmitter, I used the stylus on the GUI to change the fine during the bind period. In reading the other threads, as well as my own experience, you need to have the tx and heli close to each other to bind the first time.
Looking at your sequence I would make a few changes (for the safety of yourself and others, remove the blades before this procedure)
1. Set up the model in the transmitter with a fixed ID not 123456.. I used 17046, xmit power to about 30mw.
2. Choose the S-FHSS protocol and set the fine and coarse to 0
3. Set your heli within about 20-30 cm 8-12" of the transmitter
4. On the K120, plug in the battery, wait a moment, then press and hold the button until the red light goes out.
5. On the transmitter click on reinit. If you get a link, great, otherwise you need to adjust the freq.
6. In my case I was able to use the arrows on the fine tuning bar to adjust 20 or so at a time, leaving everything turned on, and just pausing momentarily.
When the blue led lights up, you have bind. I then powered off the heli and tx, and powered on the tx, then heli, and everything was working correctly.
The linked threads discuss how to center the frequency for most reliable operation.
- richardclli
16 Jul 2017 05:01 #63479
by richardclli
I finally got the heli bind, thanks. I think the essential factor is to lower the power.
Time to create page: 0.808 seconds
- K120 Config File
