How to bind Devo 10?
14 Mar 2018 20:38 - 14 Mar 2018 20:39 #68064 by Sebastian
How to bind Devo 10? was created by Sebastian
Hello everyone,
I installed the last Nightly Build (v5.0.0-658a6f2) to my Devo 10 to enable the FrSkyX protocol. I want to bind to a xm+ receiver. But I am not able to change the output power, it is always default. When I click "re-init" nothing happens. What am I doing wrong?
Last edit: 14 Mar 2018 20:39 by Sebastian.
15 Mar 2018 04:00 #68070 by vlad_vy
Replied by vlad_vy on topic How to bind Devo 10?
Do you have installed 4in1 module or any C2500 based module? Do you enable additional modules at "hardware.ini"?
15 Mar 2018 10:29 #68077 by Sebastian
Replied by Sebastian on topic How to bind Devo 10?
Yes, the 4 in 1 modul is installed. The ini file was already as it should be, I just changed "enable-nrf24l01" from A14 to B7. It says now:
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
But stil the same problem. Can't change tx power with frsky protocols, and if I hit "re-init" or "bind" with any protocol nothing happens.
15 Mar 2018 10:39 #68078 by vlad_vy
I think something wrong with "hardware.ini". You can't change power if "has_pa-cc2500 = 0". Edit source "hardware.ini" file with "Notepad+", check for unnecessary "spaces" at the end of options ans so on.
15 Mar 2018 11:19 #68081 by Sebastian
This is my whole ini file:
";Only useful for transmitters with an after-market vibration motor
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=
;Audio player connected to UART (Devo12/S internally, others via trainer port): audiofx, dfplayer
;voice=
;Enable if audio device is wired to uart5 instead of ppm on devo7e-256
;voice-uart5=1
;extra-buttons=
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = B7
; has_pa-nrf24l01 = 1
; enable-multimod = A13"
15 Mar 2018 11:23 - 15 Mar 2018 11:26 #68082 by vlad_vy
I see you have commented out all modules, you need remove semicolon in front of used modules:
[modules]
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
Last edit: 15 Mar 2018 11:26 by vlad_vy.
15 Mar 2018 11:32 #68085 by Sebastian
Seems to work, thank you very much!
15 Mar 2018 16:40 #68095 by Sebastian
Happy too soon. I can hit bind but no matter which firmware I use (EU, non EU) or freq fine (0 to -40) the red led flashes of the xm+ when powering up after binding.
15 Mar 2018 17:01 #68096 by vlad_vy
First, it can be bound but Freq-Fine incorrect. Try to change Freq-Fine on the fly, if you lucky you will get green LED.
Second, probably you do not hit correct Freq-Fine. Try all possible values -127 to +127 with step 10.
15 Mar 2018 18:45 #68101 by Sebastian
I am half way done, always with the same results and i doubt this will change but I keep on. Is there a way to see that binding is in progress because the LEDs just show a solid green and a solid red LED when in binding mode.
15 Mar 2018 19:18 #68104 by vlad_vy
It should flash RED if bind completed.
15 Mar 2018 19:23 #68105 by Sebastian
Right after binding or after powering on again? Mine ist just flashing red after powering on again, during binding, even when the tx has finished, it does nothing.
15 Mar 2018 20:52 - 15 Mar 2018 20:53 #68109 by aMax
Replied by aMax on topic How to bind Devo 10?
...receiver not really set to bind mode?
To use this tiny button on the XM+ is a bit tricky.
The center frequence is not far off from zero, this receiver is not a cheap toy grade receiver.
..m2c
Last edit: 15 Mar 2018 20:53 by aMax.
15 Mar 2018 21:18 #68110 by Sebastian
When I am not in bind mode just the red LED is flashing. If i hit the button I get a solid green and a solid red LED. I found this thread which lets me think I got a faulty rx: intofpv.com/t-xsr-wont-bind-to-qx7
I ordered the S.Port Tool Kit from Hobbyking to flash a new firmware. Hopefully it is not the tx that is faulty. Is it right that there is no indication in the radio whether binding was succsessful or not? Or even that there is a device in binding mode.
15 Mar 2018 22:34 - 15 Mar 2018 22:47 #68114 by aMax
But you know that this button has a double function..? Pressing at power on (short press) sets the receiver into bind mode.
A short press while powered ( max 1 second) programms the fail-safe.
Unlucky my receiver is buried in the quad and hardly to reach, so I can not verify what the leds are showing.
Edit: The most recent firmware for this receiver is "170313" and if your receiver has the "newer" 10cm antennas, the firmware
should be right on it.
( works with Devo, Taranis & 4in1)
Last edit: 15 Mar 2018 22:47 by aMax.
16 Mar 2018 10:04 #68126 by Sebastian
I did not know that there is a funktion when the receiver is already powered up but I know how to access binding mode. The button is easy to reach, the receiver is build in an Emax Babyhawk r and the button is right next to a hole in the canopy. I measure ca. 9 cm for the antennas. Still not able to bind, two solid LEDs in binding mode, one flashing red LED when not in binding mode. Independent of the transmitter is powered off or on.
16 Mar 2018 14:00 #68131 by aMax
Only one option left..
What is in your ID field? Standart 123456 ? Clear this field and use reinit if you have not already tried this.
After a bind was successfull, there should be a computed ID shown, not at once, but if you move to this field and press ENTER.
If there is a number show , navigate to "done".to confirm this.
16 Mar 2018 14:35 #68132 by Sebastian
If I clear the the ID after binding it is 123456 again. If I enter for example 1, after binding it is stiil one, but the red LED on the receiver is flashing. Each binding procedure takes exact 10 seconds, even there is no devide in binding mode.
Can you say what is defective, the radio or the receiver?
16 Mar 2018 18:46 - 16 Mar 2018 18:50 #68136 by aMax
Clear not after bind BUT before bind.... to get the "reinit" option.....
The ID has to be 6 numbers not only 1.
If you have no other receiver, which is known to work , it is hard to guess if there is a defect.
Try the reinit function. and do not only try to bind with the standart ID.
If you don´t leave the model menue or load a different model after clear, the standart ID will stay there for ever,.......
because the Devo does not save it to your current model file.
Edit: BTW, from where did you get the XM+?
Last edit: 16 Mar 2018 18:50 by aMax.
16 Mar 2018 19:08 #68137 by Sebastian
The receiver is from a german commercial ebayer so I mostly tried EU but I also tried non EU. It makes do difference which ID I choose, it doesn't work at all. But it get saved, even ID 1. I don't get a re-init option, it says always bind. But I tried model 1 - 3.
Time to create page: 0.293 seconds
