How to bind Devo 10?
- aMax
16 Mar 2018 20:08 #68140
by aMax
Replied by aMax on topic How to bind Devo 10?
You are right, only the Devo protocol gives the re-init option if the ID is cleared.
Sorry, just did a test on that.
It has been a long time ago I set these D16 receivers up,..........running out of ideas........
- Sebastian
16 Mar 2018 20:37 #68142
by Sebastian
Replied by Sebastian on topic How to bind Devo 10?
I ordered a R-XSR two month ago. I will wait two more weeks for it to arrive, then I buy a new one. But if binding fails again, what to do? Send the radio to walkera?
- aMax
16 Mar 2018 21:30 #68144
by aMax
No chance with Walkera. Btw, your transmitter is working and it could only be an issue with your 4in1 module.
Any other model to try with your transmitter? At which power setting do you try to bind, should not be obove 1mW or keep
some distance ( 2m ) to the model.
For the leds, if you get a solit green and red, your protocol is wrong, switch to the other one.
- Sebastian
16 Mar 2018 22:06 #68145
by Sebastian
I always get a solid green and red LED when power up the receiver with pressed button, no matter if the transmitter is on or off or which protocol I use (tried both). I tried binding with 30 -100 mw. I just tried it with 1 mw and 2 meters distance and, who would have expected, no success. Two solid LEDs in binding mode, one flashing LED when not in binding mode, no matter what I do.
16 Mar 2018 22:38 #68146
Replied by hexfet on topic How to bind Devo 10?
I don't think there's a way to determine whether it's the tx or rx just having those two items with the current symptoms. Need to check using another receiver or transmitter. Could inspect the 4in1 installation again. Double-check the connections and that they match the hardware.ini.
- Sebastian
16 Mar 2018 22:58 #68148
by Sebastian
My connections are like this:
www.koptertreff.de/images/own/Devo10_03.jpg
My hardware.ini is:
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
enable-nrf24l01 = B7
has_pa-nrf24l01 = 1
; enable-multimod = A13
My hardware.ini is:
enable-a7105 = A13
has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
16 Mar 2018 23:04 #68149
Looks good to me.
Time to create page: 0.086 seconds
- How to bind Devo 10?
