Need add on module in T8SG to bind SYMA ?
02 Jan 2019 22:52 - 02 Jan 2019 22:52 #72179 by CLINT
Hello
Sorry for my poor English… :)
I have just bought à T8SJ PLus V2.0 to use with my Drone Navigator 169V (like a same as Syma X5c i think)
I keep the firmaware whitch was installed (v5.0.0), but when I try to bind it doesn't work…
I'm in flight Mode 1 (trottle at right stick)
So I have a question : are you agree that additional Module isn't needed in my case (SYma) ? Because finally it is not clear for me… because the spécifications of the T8SG says that protocol Syma is native but manuel says that protocol is supported with add on module !
So I Don't know how to think… and need your hel p :) :) :)
Thank you very very much… and happy new year ! :)
Clint
Last edit: 02 Jan 2019 22:52 by CLINT.
02 Jan 2019 23:26 #72181 by Fernandez
Replied by Fernandez on topic Need add on module in T8SG to bind SYMA ?
Devation is originally based on Devo radios, extra rf modules were added to get extra protocols etc.
The Jumper radios are full open radios and have all RF modules installed to support the full deviation protocol library natively.
I have no experience with Syma myself, but should work.
03 Jan 2019 00:47 #72182 by hexfet
Replied by hexfet on topic Need add on module in T8SG to bind SYMA ?
Try turning on the X5C protocol option. Click on the protocol name to access the options. If it's really a rebranded X5C that should work.
03 Jan 2019 14:39 #72190 by CLINT
Replied by CLINT on topic Need add on module in T8SG to bind SYMA ?
Thank you for your answer !
I have tried with X5C protocol option, it doesn't work…
Well may be Navigator 169V drone is not the same protocol than Syma… if someone have info..
Thank you
Clint
PS : I have just tried T8SG Plus V2.0 also with my Blade MCX hélico and all is ok, great !!
06 Jan 2019 00:31 #72211 by CLINT
Hello
Well, I've take a look at radio and drone chipset : LT5910 for the drone and LT8910 for the radio
I'm not sure T8SG Plus V2.0 has a compatible protocole, i have search and read messages on the forum but I Don't find more than discussion about how to try to émulate.
Is ok now ?
Thanks very much
Clint
06 Jan 2019 11:41 #72213 by goebish
Replied by goebish on topic Need add on module in T8SG to bind SYMA ?
LT8910 transceiver isn't supported so far.
06 Jan 2019 20:41 #72217 by CLINT
Well, a little disappointed but thank you goebish for your confirmation.
Regards
Clint
10 Feb 2019 23:59 #72850 by CLINT
Hello
Any more news ?
Thks
Time to create page: 0.074 seconds
