- Need add on module in T8SG to bind SYMA ?
- CLINT
02 Jan 2019 22:52 - 02 Jan 2019 22:52 #72179
by CLINT
Need add on module in T8SG to bind SYMA ? was created by CLINT
Hello
Sorry for my poor English…
I have just bought à T8SJ PLus V2.0 to use with my Drone Navigator 169V (like a same as Syma X5c i think)
I keep the firmaware whitch was installed (v5.0.0), but when I try to bind it doesn't work…
I'm in flight Mode 1 (trottle at right stick)
So I have a question : are you agree that additional Module isn't needed in my case (SYma) ? Because finally it is not clear for me… because the spécifications of the T8SG says that protocol Syma is native but manuel says that protocol is supported with add on module !
So I Don't know how to think… and need your hel p
Thank you very very much… and happy new year !
Clint
Clint
Last edit: 02 Jan 2019 22:52 by CLINT.
- Fernandez
02 Jan 2019 23:26 #72181
by Fernandez
Replied by Fernandez on topic Need add on module in T8SG to bind SYMA ?
Devation is originally based on Devo radios, extra rf modules were added to get extra protocols etc.
The Jumper radios are full open radios and have all RF modules installed to support the full deviation protocol library natively.
I have no experience with Syma myself, but should work.
03 Jan 2019 00:47 #72182
Replied by hexfet on topic Need add on module in T8SG to bind SYMA ?
Try turning on the X5C protocol option. Click on the protocol name to access the options. If it's really a rebranded X5C that should work.
- CLINT
03 Jan 2019 14:39 #72190
by CLINT
Replied by CLINT on topic Need add on module in T8SG to bind SYMA ?
Thank you for your answer !
I have tried with X5C protocol option, it doesn't work…
Well may be Navigator 169V drone is not the same protocol than Syma… if someone have info..
Thank you
Clint
PS : I have just tried T8SG Plus V2.0 also with my Blade MCX hélico and all is ok, great !!
Thank you
Clint
- CLINT
06 Jan 2019 00:31 #72211
by CLINT
Hello
Well, I've take a look at radio and drone chipset : LT5910 for the drone and LT8910 for the radio
I'm not sure T8SG Plus V2.0 has a compatible protocole, i have search and read messages on the forum but I Don't find more than discussion about how to try to émulate.
Is ok now ?
Thanks very much
Clint
Is ok now ?
Thanks very much
Clint
- goebish
- NRF Weirdo
06 Jan 2019 11:41 #72213
by goebish
Replied by goebish on topic Need add on module in T8SG to bind SYMA ?
LT8910 transceiver isn't supported so far.
- CLINT
06 Jan 2019 20:41 #72217
by CLINT
Well, a little disappointed but thank you goebish for your confirmation.
Regards
Clint
Regards
Clint
- CLINT
10 Feb 2019 23:59 #72850
by CLINT
Hello
Any more news ?
Thks
Any more news ?
Thks
Time to create page: 0.897 seconds
