T8SG Lite
- Qmike
11 Jan 2019 16:54 #72281
by Qmike
Replied by Qmike on topic T8SG Lite
Corrupted file system is history!!!!
I can format and I can transfer data again.
Unfortunately a messages on the RC appears which says "Missing Modules CYRF 6936 .."
In Hardware.ini I can enable or disable this text it will not change the messages.
Any idea? (I will check the sources if this file is missing).
- Qmike
- Qmike
11 Jan 2019 18:07 - 11 Jan 2019 18:08 #72285
Replied by vlad_vy on topic T8SG Lite
Change hardware.ini
[modules]
enable-cyrf6936 = 0
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
; enable-nrf24l01 = A15
; has_pa-nrf24l01 = 1
; enable-multimod = A13
Last edit: 11 Jan 2019 18:08 by vlad_vy.
- Qmike
11 Jan 2019 19:27 #72288
by Qmike
Halleluja!
Many thanks for your support. You are my man.
The procedure itselfes is easy but the way is difficult.
I'm quite happy to do the compiling on a Ubuntu OS.
Even when the (source)files where a kind of "hidden" in var/snap/docker/..., the docker enviroment makes it easy to compile.
Your build "assistant" also is a fun to work with.
Will see, if I assemble the "how to" for the T8SG Lite.
By the way, does it make sense to put T8SG Lite as Build online?
So far, none exist.
Again, many thks. for your helping hand!!!
So far, none exist.
- Qmike
12 Jan 2019 12:07 - 12 Jan 2019 12:11 #72296
by Qmike
Yes vlad_vy, you are spot on right but I guy like me was not in the know of such similarity. So maybe a small remark in the downloads will do the job.
Concerning your small change in the targets_def.h this was the trigger for restructering/initializing the file system which then shows 4mb not 2mb as before.
Modells etc. need to be adapted but this is a peace of cake.
Anyway, you have giving me a helping hand and that counts.
Cheers
Qmike
Cheers
Qmike
Last edit: 12 Jan 2019 12:11 by Qmike.
23 Jan 2019 12:43 - 23 Jan 2019 12:46 #72498
Now "t8sg_v2" firmware has flash memory auto detect enabled (from 24 January nightly build), so I think it can be used as firmware for T8SG Light, with changed "hardware.ini".
;enable-haptic=1
;switch_types: 3x4, 3x3, 3x2, 3x1, 2x8, 2x7, 2x6, 2x5, 2x4, 2x3, 2x2, 2x1, potx2, potx1
;Add nostock if stock FMOD and HOLD switches have been removed.
extra-switches = nostock
extra-switches = 3x4
; extra-switches = 2x2
extra-switches = potx2
;extra-buttons=
[modules]
enable-cyrf6936 = 0
; has_pa-a7105 = 1
enable-cc2500 = A14
has_pa-cc2500 = 1
Last edit: 23 Jan 2019 12:46 by vlad_vy.
Time to create page: 0.131 seconds
