Devo 12s switch problem
- ferreret
24 Jan 2019 08:29 #72513
by ferreret
Devo 12s switch problem was created by ferreret
Hello! I'm programing my devo 12s with deviation 5.0.0 to use with a DJI dron. I need to assign two channels with a potentiometer switch, but after many tests all the times the potentiometer runs likes a two position switch(only on-off). If I asign this aux channel with an stick(elevator), then runs perfect with progressive position. Any idea why I can't run this switch like a progressive switch?
Thank you for advanced
24 Jan 2019 09:46 - 24 Jan 2019 09:56 #72515
Replied by vlad_vy on topic Devo 12s switch problem
Any analog input can be used as "Src" for channel mixer.
Also, are you sure that you calibrate AUX pots along with sticks?
Last edit: 24 Jan 2019 09:56 by vlad_vy.
- Gerry
- Bbrad
24 Jan 2019 10:57 #72516
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Devo 12s switch problem
have you tried calibrating the tx including pots?
- ferreret
24 Jan 2019 18:06 #72518
by ferreret
Replied by ferreret on topic Devo 12s switch problem
Thank you very much for yours answers!
- ferreret
25 Jan 2019 21:35 #72529
by ferreret
You are right, after calibrating the rudders runs perfect!
Time to create page: 0.168 seconds
- Devo 12s switch problem
