DEVO 6
- clearprop88
- clearprop88
- dado099
- kcornels
10 Sep 2012 19:25 #1476
Doing a proper port to the Devo12 is a lot of work because it has a lot more capabilities than the other models. It is also a lot more expensive which makes it a less attractive target for me.
It may happen some day but I will probably do all of the cheaper models 1st.
Replied by PhracturedBlue on topic DEVO 6
I need a FAQ.kcornels wrote: do you have any plan, to make it work with a devo12 ?
The bigger display may be really usefull... .
- DemonOfPyro
- ju211
12 Sep 2012 07:50 - 12 Sep 2012 07:51 #1555
by ju211
Replied by ju211 on topic DEVO 7
Is there any plan to support devo 7?
I am not sure how hard this would be considering the screen difference. On top of the technical challenge, there is an ergonomic point to do better than the original firmware.
Last edit: 12 Sep 2012 07:51 by ju211. Reason: get notified of replies
12 Sep 2012 12:16 #1558
Replied by PhracturedBlue on topic DEVO 7
At the moment I don't think so. The screen is too limited, and without USB, programming is annoying. I have one, but I think defining the menus with a fixed-segment display is going to be an effort in frustration. I do plan to support the 7e though since it should be similar to the Devo10.ju211 wrote: Is there any plan to support devo 7?
- ju211
12 Sep 2012 22:30 #1566
by ju211
To be honest, I think the devo7 display is close from useless.
What would be very interesting, is a possibility to program helis (including 24XX rx) on the computer and push them the devo7. The UI is already such a mess that I would not change configuration on the field anyway.
So imo you would not really have to define the menus.
- upside_down
14 Sep 2012 08:10 #1593
Replied by FDR on topic DEVO 6
I think the 8 lib should work, because they have the same size flash at the same address, but you can try it the other way: format the drive in USB mode, and copy the contents of the filesystem directory to it.
The DEVO 6 target is brand new and yet unpublished.
PB could tell...
PB could tell...
- upside_down
14 Sep 2012 09:13 #1595
by upside_down
Replied by upside_down on topic DEVO 6
Going back to walkera DEVENTION FWDT v0.6A and Lib v0.3
The bind-screen now shows a white bar on top (top ~ 2px, height ~ 40px, width = 320px).
Trying with FWDT v 0.5A and Lib v 0.3.FDR.v3 could not solve this.
Then i upgraded again to the DEVIATION devo6.dfu (d44742f64ed5)
Leave DFU mode.
Result:
Black screen.
Backlight is on.
No message to format via PC.
Explorer show no USB drive.
Tx off
Tx on with EXT
Upload Lib (from first devo8 release) with DfuSe
Leave DFU mode
Same result as above.
Leave DFU mode.
Result:
Black screen.
Backlight is on.
Tx off
Tx on with EXT
Leave DFU mode
14 Sep 2012 09:26 #1596
Weird, because the original lib (and mine as well) contains that screen, it looks like if it couldn't write that memory properly...
BTW the installation procedure of deviation without the lib is:
After upgrading to the deviation dfu you should turn off, then turn it on holding ENT. It will go into the USB mode, but since the "drive" is not formatted, Windows will offer to format it. Format using default settings, then copy the contents of the filesystem directory (5 dir + tx.ini) to it...
- upside_down
14 Sep 2012 09:53 #1597
by upside_down
...turn on the tx with ENT pressed was it (i am ashamed)
After copying the content of the filesystem directory to the tx all is running.
Thanks for your help.
ps: d44742f64ed5 holds only 4 dir and no tx.ini
I have used an older version for now.
- upside_down
Time to create page: 0.606 seconds
