DEVO 6
09 Sep 2012 22:42 #1440 by clearprop88
DEVO 6 was created by clearprop88
Can I download the Firmware update to my Devo 6 at this time?
09 Sep 2012 23:53 #1443 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 6
Not yet.
while I do not expect adding support to the Devo6 to be difficult, I don't own one, and so I haven't been able to tweak the code to support it yet.
10 Sep 2012 00:57 #1444 by clearprop88
Replied by clearprop88 on topic DEVO 6
I'll loan you mine. I'm not using it now. I'm using my 2801 Pro.
Let me know.
10 Sep 2012 12:32 #1466 by dado099
Replied by dado099 on topic DEVO 6
I own a Devo 6,
I'm the queue.... :) :) :)
10 Sep 2012 12:38 #1467 by PhracturedBlue
I've discussed with clearprop, if things go smoothly, I'll have his this week. I only expect it to be a couple of hours of work to get functional (fingers crossed)
10 Sep 2012 19:04 #1473 by kcornels
Replied by kcornels on topic DEVO 6
do you have any plan, to make it work with a devo12 ?
The bigger display may be really usefull... .
10 Sep 2012 19:25 #1476 by PhracturedBlue
kcornels wrote: do you have any plan, to make it work with a devo12 ?
I need a FAQ.
Doing a proper port to the Devo12 is a lot of work because it has a lot more capabilities than the other models. It is also a lot more expensive which makes it a less attractive target for me.
It may happen some day but I will probably do all of the cheaper models 1st.
10 Sep 2012 21:52 #1485 by DemonOfPyro
Replied by DemonOfPyro on topic DEVO 6
I'm on board for the Devo 12s idea, I have been following this for the past few months in hopes there would be a Devo 12s release. =\
Please make this happen!
12 Sep 2012 07:50 - 12 Sep 2012 07:51 #1555 by ju211
Replied by ju211 on topic DEVO 7
Is there any plan to support devo 7?
I am not sure how hard this would be considering the screen difference. On top of the technical challenge, there is an ergonomic point to do better than the original firmware.
Last edit: 12 Sep 2012 07:51 by ju211. Reason: get notified of replies
12 Sep 2012 12:16 #1558 by PhracturedBlue
Replied by PhracturedBlue on topic DEVO 7
ju211 wrote: Is there any plan to support devo 7?
At the moment I don't think so. The screen is too limited, and without USB, programming is annoying. I have one, but I think defining the menus with a fixed-segment display is going to be an effort in frustration. I do plan to support the 7e though since it should be similar to the Devo10.
12 Sep 2012 22:30 #1566 by ju211
To be honest, I think the devo7 display is close from useless.
What would be very interesting, is a possibility to program helis (including 24XX rx) on the computer and push them the devo7. The UI is already such a mess that I would not change configuration on the field anyway.
So imo you would not really have to define the menus.
14 Sep 2012 07:56 #1592 by upside_down
Replied by upside_down on topic DEVO 6
There is the devo6 target now on the deviation code.
Does this mean the devo6 should run with this code?
I have tried it and have no success (screen was black).
I used the library from the first release (devo8).
14 Sep 2012 08:10 #1593 by FDR
Replied by FDR on topic DEVO 6
I think the 8 lib should work, because they have the same size flash at the same address, but you can try it the other way: format the drive in USB mode, and copy the contents of the filesystem directory to it.
The DEVO 6 target is brand new and yet unpublished.
PB could tell...
14 Sep 2012 09:13 #1595 by upside_down
Going back to walkera DEVENTION FWDT v0.6A and Lib v0.3
The bind-screen now shows a white bar on top (top ~ 2px, height ~ 40px, width = 320px).
Trying with FWDT v 0.5A and Lib v 0.3.FDR.v3 could not solve this.
Then i upgraded again to the DEVIATION devo6.dfu (d44742f64ed5)
Leave DFU mode.
Result:
Black screen.
Backlight is on.
No message to format via PC.
Explorer show no USB drive.
Tx off
Tx on with EXT
Upload Lib (from first devo8 release) with DfuSe
Leave DFU mode
Same result as above.
14 Sep 2012 09:26 #1596 by FDR
Weird, because the original lib (and mine as well) contains that screen, it looks like if it couldn't write that memory properly...
BTW the installation procedure of deviation without the lib is:
After upgrading to the deviation dfu you should turn off, then turn it on holding ENT. It will go into the USB mode, but since the "drive" is not formatted, Windows will offer to format it. Format using default settings, then copy the contents of the filesystem directory (5 dir + tx.ini) to it...
14 Sep 2012 09:53 #1597 by upside_down
...turn on the tx with ENT pressed was it (i am ashamed)
After copying the content of the filesystem directory to the tx all is running.
Thanks for your help.
ps: d44742f64ed5 holds only 4 dir and no tx.ini
I have used an older version for now.
14 Sep 2012 10:07 #1598 by FDR
Yep, but the build will create them...
14 Sep 2012 10:40 #1599 by upside_down
I am ashamed again.
Thank you.
14 Sep 2012 10:44 #1602 by FDR
It's not a shame, it is not documented...
Time to create page: 1.094 seconds
