- Tarot ZYX-S issue using satellite receiver
- Wene001
29 Oct 2012 06:52 #2465
by Wene001
Replied by Wene001 on topic Tarot ZYX-S issue using satellite receiver
I can do a test in 7 Channel Mode with the ZYX later this week.
With the Orange 6+9Ch Receiver it seems there isnt this stuttering issue
- Wene001
30 Oct 2012 16:10 #2505
by Wene001
devo8-87729ce290cb
Now it looks like the stuttering is gone.
6 Channel Mode likes like a charm.
Tx in 7 channel Mode the ZYx-s Led is blinkin Tx Error
Zyx Software says Channel Pitch, Elevatot, Aileron moving as expected
Channel Rudder and Tail Gain doesn`t move
- flint723
17 Nov 2012 22:20 - 17 Nov 2012 23:57 #2968
by flint723
So you did get the zyx-s to work with just a sat? I have been trying for a couple hours, binding sat with rx and with zyx, different number of channels in tx, all the different dsm2 options in the zyx, and have been having no luck at all. I'm using a spektrum ar6200's sat.
Edit: Finally got it to work, the secret seemed to be to use the Tarot software V3.0 rather than john_nz's software. It worked the first time I tried it with the Tarot software. With binding the sat to an external rx first, then putting it on the zyx, using the set button to boot the zyx past the yellow light, and setting dsm2-1 in software. Also it is using 6ch dsm2 in the tx.
Replied by flint723 on topic Tarot ZYX-S issue using satellite receiver
Wene001 wrote: devo8-87729ce290cb
Last edit: 17 Nov 2012 23:57 by flint723.
- Wene001
18 Nov 2012 17:49 #2984
by Wene001
I did it the same way
- notyet
29 Jun 2013 14:07 - 29 Jun 2013 14:21 #11560
by notyet
Replied by notyet on topic Tarot ZYX-S issue using satellite receiver
Sorry to resurrect the old thread-
Did anyone ever get it to bind in seven channel mode? In six channel mode gyro sense doesn't seem to work anymore. I can't figure out how to adjust tail gyro gain in this case.
Any suggestions?
Any suggestions?
Last edit: 29 Jun 2013 14:21 by notyet.
29 Jun 2013 14:16 #11561
Replied by vlad_vy on topic Tarot ZYX-S issue using satellite receiver
What firmware version do you use?
- notyet
29 Jun 2013 16:11 - 29 Jun 2013 23:10 #11572
by notyet
The tarot is 3.5 I believe. Deviation is a nightly from about three weeks ago on Devo 10
Last edit: 29 Jun 2013 23:10 by notyet.
- notyet
05 Jul 2013 14:10 #11949
by notyet
I'm obviously missing something about the zyx-s. It works for people with dx6i which is only 6 channels, so its obviously capable of doing it.
Is anyone with a zyx-s able to control tail gyro gain from the transmitter?
- Ceasar
05 Jul 2013 15:46 #11953
by Ceasar
Replied by Ceasar on topic Tarot ZYX-S issue using satellite receiver
Hi
Yes that works for me, throu channel 5 connected to AUX5 on devo10(1ae61a3d88c3)
Running ZYX-S(v4.01 mode=dsm2-1) with Orange sat(first bound with 6ch orange-rx 610) on my Align Trex 250Pro DFC.
- notyet
05 Jul 2013 18:36 #11961
by notyet
In the ZYX-S software, do you see the tail gyro gain changing on the monitor page along with other controls?
- Ceasar
06 Jul 2013 17:16 #12017
by Ceasar
Yes, on the setup page I see tail gain change when changing aux5 knob connected on ch5.
I use 6 channel dsm2 mode in the devo10.
I also use Mix1 switch for rate mode.
- TF824
09 Feb 2014 04:04 - 09 Feb 2014 04:13 #20010
by TF824
Replied by TF824 on topic Tarot ZYX-S issue using satellite receiver
Hi, I'm trying to fix my Devo7e(deviation installed) to work with Tarot ZYX+DSM2 Satelite. Tried to open this link
www.deviationtx.com/forum/5-news-announc...-dsm2-telemetry#2445
but it shows ''You don't have permission to access this page....
Any idea? Thx. Ty
Any idea? Thx. Ty
Last edit: 09 Feb 2014 04:13 by TF824.
09 Feb 2014 09:13 #20014
Replied by rbe2012 on topic Tarot ZYX-S issue using satellite receiver
Probably the thread was moved into another section. I haven't found it too.
Maybe there is a way to search for post #2445?
- TF824
10 Feb 2014 04:54 #20049
by TF824
I have Deviation 3.0 installed on my Devo7E. Anybody knows if I install V4.0.1, Tarot ZYX with DSM2 satelite works with my Devo7E?
- micro
15 Feb 2014 04:13 - 15 Feb 2014 04:14 #20292
by micro
Replied by micro on topic Tarot ZYX-S issue using satellite receiver
If it helps I could notget trex 150 working with dsm2 lemon sat until I updated v3 to v4. May help?
I dare not try a zyx with deviation yet as still learnig the ropes with this firmware and heli setups
Last edit: 15 Feb 2014 04:14 by micro.
- esklarski
15 Feb 2014 11:16 #20297
by esklarski
Replied by esklarski on topic Tarot ZYX-S issue using satellite receiver
Not that this helps much, as my heli is a long drive away right now. But I have a Trex250 with zyx-s and a spektrum satelite I'm in the tuning phase of building, and I had no troubles binding directly throught the zyx-s software.
That was with Deviation 3.0, things work fine under 4 too! I never knew there was trouble to be had with this combo. Don't give up it can work.
Time to create page: 0.106 seconds
