Range problem on Devo6
- OnceAFly
25 Jan 2013 02:36 #5489
by OnceAFly
Range problem on Devo6 was created by OnceAFly
I'm having very short range problem on devo6 deviated only not more then 20-30m control. I have replaced the tx module without improvement...
Have removed the v911 module also even load back devo firmware won't help too. Is there any expert can help me with this?
25 Jan 2013 05:21 - 25 Jan 2013 05:22 #5495
Replied by FDR on topic Range problem on Devo6
Welcome!
Sorry, but I have to ask, what power setting do you use?
If that is correct, I would check the antenna plug and wire...
Last edit: 25 Jan 2013 05:22 by FDR.
- Sunwalker
25 Jan 2013 08:58 #5500
by Sunwalker
Replied by Sunwalker on topic Range problem on Devo6
The problem is not the Devitation. But the Devo 6 has a short antenna this is the Problem .
I had some time ago the same problem.
The antenna in the devo 6 is very thin and small.
a small crack and it does not reach more
You have to replace the antenna here are a few Links of the antennas fit.
hobbyking.com/hobbyking/store/__25381__O...cement_antenna_.html
www.rc-toy.de/cosmoshop/cgi-bin/lshop.cg...&source=froogle&ls=d
- OnceAFly
29 Jan 2013 01:48 - 29 Jan 2013 01:59 #5689
by OnceAFly
Replied by OnceAFly on topic Range problem on Devo6
Last edit: 29 Jan 2013 01:59 by OnceAFly.
- kille
29 Jan 2013 09:19 #5704
by kille
Replied by kille on topic Range problem on Devo6
I think the problem is the v911 receiver.
www.deviationtx.com/forum/3-feedback-que...lysky-mod-range-test
- OnceAFly
29 Jan 2013 09:30 #5705
by OnceAFly
Nope have taken out the v911 module still same problem.
- kille
29 Jan 2013 09:38 #5706
by kille
I'm sorry I haven't carefully read your post.
- OnceAFly
30 Jan 2013 13:19 #5783
by OnceAFly
Its ok
just maybe best option is send it back to walkera...
- MiG_31
28 May 2013 15:27 #10367
by MiG_31
Replied by MiG_31 on topic Range problem on Devo6
Hey Guys!
Looks I'm having the same problem with my devo6s. I have installed XL7105-D03 module. All worked well indoors, but when I tried to fly outdoors, I find out that both modules have very limited range (about 15-25 meters on highest power output setting). I have tried unsoldering 705 module and reverting to walkera software with no success, range remains limited. Range increase from lowest to highest output settings is about 10 meters only. So 10m with 300uW and 15-20m with 150mW. If anyone has an idea, what should I check, before buying a new radio for outdoors, please post it here.
Time to create page: 0.809 seconds
- Range problem on Devo6
