devo8s color bars and will not turn off
02 Mar 2013 19:30 #7224 by bobball
i ded all the downloads for 8s now when i turn it on all i get is color bars and it will not turn off to turn it off i must put in progran update mode then turn it off
02 Mar 2013 19:46 - 02 Mar 2013 20:41 #7225 by RandMental
Replied by RandMental on topic devo8s color bars and will not turn off
Hi
Clearly someting went wrong and the new firmware is not running, but the bootloader still is. That means it is unlikely that you have a hardware problem.
I would suggest go back to the Devention software, reload it just as you would do an upgrade with new Devo firmware, using the Walkera dfuse tool. Once that is up and running, start over and make sure you follow the steps in the manual or look at one of Tom Z's videos. ( it is all on this site)
Last edit: 02 Mar 2013 20:41 by RandMental.
02 Mar 2013 20:10 #7226 by bobball
Replied by bobball on topic devo8s color bars and will not turn off
Thanks for getting back to me i started all over whith the new devo firmware and that is where i ran into the color bars
02 Mar 2013 20:12 #7227 by FDR
Replied by FDR on topic devo8s color bars and will not turn off
Then most likely you library dfu file is corrupted, because you uploaded it instead of upgrading.
Download the library dfu again, and make sure to choose UPGRADE on the dfuse tool...
02 Mar 2013 23:50 #7232 by bobball
Thanks FDR that was wat i was doing it is working now
Time to create page: 0.113 seconds
